Ωhm Posted March 31, 2021 Share Posted March 31, 2021 8 minutes ago, Pete M said: wait, what? why or how could an older engine even do that? Its a characteristic on engine shut down, any engine. I guess one would have to look where the rotor tip is when vehicle is SHUT OFF. Link to comment Share on other sites More sharing options...
Pete M Posted March 31, 2021 Share Posted March 31, 2021 all I know is that no engine I've ever worked on has been in the same place when I go to find TDC. maybe they were referring to modern engines with the quick-startup feature. Link to comment Share on other sites More sharing options...
Ωhm Posted March 31, 2021 Share Posted March 31, 2021 No, I took it as any and all engines. If true it could explain wear and tear on starter ring teeth or maybe its just a bunch of bullfeces. Link to comment Share on other sites More sharing options...
Eagle Posted March 31, 2021 Share Posted March 31, 2021 1 hour ago, Ωhm said: A engine guy once told me when you shut the engine OFF it will always stop at the same point in terms of the crank position. Could just be 35 years of starter engagement hitting at the same spot on the flywheel. Off the top of my head, I'm going to say that's totally impossible. Link to comment Share on other sites More sharing options...
BeaterComanche86 Posted March 31, 2021 Author Share Posted March 31, 2021 1 hour ago, Ωhm said: A engine guy once told me when you shut the engine OFF it will always stop at the same point in terms of the crank position. Could just be 35 years of starter engagement hitting at the same spot on the flywheel. Since you got the flywheel already out, I'd take it to a shop and have them resurface it. True it up. That’s wild if that’s true, I don’t know how that would be possible but . And I think I’m gonna stop by there shop tomorrow after work so I’ll see what there price is and go from there. Can’t hurt to ask. Also I’m not pressed to get this done quickly so I’ve got time. I appreciate everyone’s input. Link to comment Share on other sites More sharing options...
Pete M Posted April 1, 2021 Share Posted April 1, 2021 I promise, my 4.0 does not do that. I would have noticed that years ago. when the power is cut, it stops in roughly the same amount of rotation and since the power can be cut at any time, that means the stopping point must be different each time. I might buy it for a modern engine though, where the computer has absolute control over things and can cut power at the same time each time. Link to comment Share on other sites More sharing options...
