zaconrad Posted March 23, 2021 Share Posted March 23, 2021 I have a 1986 Jeep Comanche and today it started. Now when I turn off the ignition and take out the key it just keeps running. I just replaced the lock cylinder so I don't think its that. Any ideas? Link to comment Share on other sites More sharing options...
jdog Posted March 23, 2021 Share Posted March 23, 2021 did you plug the single red wire into the coil? Link to comment Share on other sites More sharing options...
zaconrad Posted March 23, 2021 Author Share Posted March 23, 2021 everything on the coil looks good. Link to comment Share on other sites More sharing options...
Ωhm Posted March 23, 2021 Share Posted March 23, 2021 18 minutes ago, zaconrad said: everything on the coil looks good. Double check it. Link to comment Share on other sites More sharing options...
zaconrad Posted March 23, 2021 Author Share Posted March 23, 2021 Already did If something was wrong with the coil it wouldn't have started Link to comment Share on other sites More sharing options...
jdog Posted March 23, 2021 Share Posted March 23, 2021 if the red wire got plugged into the coil the vehicle will do this which is why we are asking Link to comment Share on other sites More sharing options...
Ωhm Posted March 23, 2021 Share Posted March 23, 2021 Find that single red wire and make sure its not plug into anything except the Engine Compartment Lamp, if equipped. Wire is HOT at all times. Link to comment Share on other sites More sharing options...
zaconrad Posted March 23, 2021 Author Share Posted March 23, 2021 I have made no changes to the coil since it was driving fine. The red wire is were its supposed to be. Link to comment Share on other sites More sharing options...
Ωhm Posted March 23, 2021 Share Posted March 23, 2021 With ENGINE RUNNING and KEY OFF. Measure for B+ at D2_4. Should show 0vdc. Link to comment Share on other sites More sharing options...
zaconrad Posted March 23, 2021 Author Share Posted March 23, 2021 I don't have a diagnostic tool. Or is there something else that I'm missing? Link to comment Share on other sites More sharing options...
jdog Posted March 23, 2021 Share Posted March 23, 2021 That's a plug in the engine bay, should have a yellow dust cap on it. Using a dvom perform the test above. Link to comment Share on other sites More sharing options...
Dzimm Posted March 23, 2021 Share Posted March 23, 2021 I had this happen on my 95 once. I ended up pulling the battery cable to get it shut off. I cleaned up the battery terminals and hooked it back up and it hasn't done it since. No idea if the battery cables were the issue or not but worth a shot I suppose. Link to comment Share on other sites More sharing options...
zaconrad Posted March 23, 2021 Author Share Posted March 23, 2021 I'm still having problems with the diagnosis. Link to comment Share on other sites More sharing options...
Ωhm Posted March 23, 2021 Share Posted March 23, 2021 Did you find the connectors D1 & D2? D2_4 pin is IGN SW feed (I1). With DVOM connected between D2_4 and Battery GND, KEY OFF, your voltage reading should show 0vdc, otherwise your IGN SW (I1) feed is shorted to voltage (B+). Link to comment Share on other sites More sharing options...
jdog Posted March 23, 2021 Share Posted March 23, 2021 they should look like this Link to comment Share on other sites More sharing options...
zaconrad Posted March 24, 2021 Author Share Posted March 24, 2021 Ok I figured it out. I don't know how but I was having alternator issues wich was the result of this problem. After I fixed my alternator problem went away. Link to comment Share on other sites More sharing options...
