shipp_m Posted March 21, 2021 Share Posted March 21, 2021 What are your thoughts between the two? Who has experience running both and what would you suggest? Fox or OME. Thanks in advance. Matt. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted March 21, 2021 Share Posted March 21, 2021 Fox has a huge lineup and wide variety of designs so it’s not easy to compare. Entry level mono tube Fox shocks would probably be the most comparable to ome. I’d vote fox since most can be custom tuned and rebuilt. I did run OME on my YJ and they were ok. Bilstein is another strong contender and what many here are running currently. Link to comment Share on other sites More sharing options...
MercManche Posted March 21, 2021 Share Posted March 21, 2021 If you are running a full OME kit, run the OME shocks, they are valved for the suspension and would give the best ride quality overall (for non adjustable shocks that is). I have Bilstein aswell, they are not specifically tuned for the springs but I don't notice a difference at all in my YJ. I do not like the bilstiens in the front (5100) as they are a bit stiff compared to the OME shocks I used to have. Fox is what I would go with if you are running anything different from the OME lift (as in not their full kit) I had a long conversation about spring rates and shock selection with ARB a while back, I agree with ghetdjc, I would just go with fox if its in your budget. Having rebuildable tunable shocks is the better choice. I have installed a set of Fox shocks on my friends JK about a year ago and it definitely made a big difference, and he loves it. Link to comment Share on other sites More sharing options...
shipp_m Posted March 22, 2021 Author Share Posted March 22, 2021 Thanks fellas. Link to comment Share on other sites More sharing options...
Comanche Ranch Posted March 23, 2021 Share Posted March 23, 2021 On 3/21/2021 at 7:45 PM, MercManche said: If you are running a full OME kit, run the OME shocks, they are valved for the suspension and would give the best ride quality overall (for non adjustable shocks that is). I have Bilstein aswell, they are not specifically tuned for the springs but I don't notice a difference at all in my YJ. I do not like the bilstiens in the front (5100) as they are a bit stiff compared to the OME shocks I used to have. Fox is what I would go with if you are running anything different from the OME lift (as in not their full kit) I had a long conversation about spring rates and shock selection with ARB a while back, I agree with ghetdjc, I would just go with fox if its in your budget. Having rebuildable tunable shocks is the better choice. I have installed a set of Fox shocks on my friends JK about a year ago and it definitely made a big difference, and he loves it. Would you mind if I ask what a full OME kit for an MJ would be? I do have a full OME kit for an XJ and it is really nice. Thanks. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted March 23, 2021 Share Posted March 23, 2021 1 hour ago, Comanche Ranch said: Would you mind if I ask what a full OME kit for an MJ would be? I do have a full OME kit for an XJ and it is really nice. Thanks. It doesn’t exist. Only the XJ front components. Link to comment Share on other sites More sharing options...
MercManche Posted March 24, 2021 Share Posted March 24, 2021 On 3/22/2021 at 9:47 PM, ghetdjc320 said: It doesn’t exist. Only the XJ front components. Contact the guys at RRO, super friendly and you will have to do SOA in the rear and front will be selected with OME parts. https://www.rocky-road.com/index2.html Thats about the only "kit" available. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted March 24, 2021 Share Posted March 24, 2021 1 hour ago, MercManche said: Contact the guys at RRO, super friendly and you will have to do SOA in the rear and front will be selected with OME parts. https://www.rocky-road.com/index2.html Thats about the only "kit" available. I’d grab a set of perches and u bolts from ruff stuff off-road if going soa. Bolt on soa is a bit sketchy imho. Link to comment Share on other sites More sharing options...
MercManche Posted March 26, 2021 Share Posted March 26, 2021 On 3/24/2021 at 12:08 AM, ghetdjc320 said: I’d grab a set of perches and u bolts from ruff stuff off-road if going soa. Bolt on soa is a bit sketchy imho. My friend used to have a comanche with their 6" kit D44 rear, never had any issues. But I agree, welding new SOA perches is the best way to go about it. Link to comment Share on other sites More sharing options...
