cruiser54 Posted March 22, 2021 Share Posted March 22, 2021 Have you removed the distributor cap and inspected it inside? FWIW, new plugs, wires, cap and rotor at every 30,000 mile tuneup. Link to comment Share on other sites More sharing options...
Epplebee Posted March 22, 2021 Author Share Posted March 22, 2021 42 minutes ago, cruiser54 said: Have you removed the distributor cap and inspected it inside? FWIW, new plugs, wires, cap and rotor at every 30,000 mile tuneup. Thats next. I didn't think it should be an issue since the PO put all new caps, plugs and wires on it before i got it. Hasn't hardly ran since he did it all. Link to comment Share on other sites More sharing options...
cruiser54 Posted March 23, 2021 Share Posted March 23, 2021 takes minutes to look. What plugs? What gaps? Link to comment Share on other sites More sharing options...
Epplebee Posted March 24, 2021 Author Share Posted March 24, 2021 On 3/22/2021 at 8:15 PM, cruiser54 said: takes minutes to look. What plugs? What gaps? Replaced plugs with proper .035 gap(po had them at .025) cap and rotor are in great shape. Doesn't seem to run as rich but still has a stumble about 1500 rpm til about 2000 rpm. My son will be home in about 3 weeks to drive this thing from Florida to Kentucky and I really need to get this thing running right but I am lost at this point. Link to comment Share on other sites More sharing options...
jdog Posted March 24, 2021 Share Posted March 24, 2021 Couple questions what plugs did you put in it have you checked the tps? Does it do it thru every gear? And is always at 1500-2000 or only in first gear? Link to comment Share on other sites More sharing options...
Epplebee Posted March 24, 2021 Author Share Posted March 24, 2021 11 minutes ago, jdog said: Couple questions what plugs did you put in it have you checked the tps? Does it do it thru every gear? And is always at 1500-2000 or only in first gear? NGK BKR5EIX plugs TPS tested good Every gear and sitting in the driveway. Always between 1500-2000 rpm. Idles great as does when i snap the throttle, but slightly increase throttle and stumble at 1500rpm Link to comment Share on other sites More sharing options...
cruiser54 Posted March 24, 2021 Share Posted March 24, 2021 Remove and cap the vacuum hose to the EGR. Link to comment Share on other sites More sharing options...
Epplebee Posted March 24, 2021 Author Share Posted March 24, 2021 8 minutes ago, cruiser54 said: Remove and cap the vacuum hose to the EGR. PO installed HO intake and exhaust manifold so there's only EGR Link to comment Share on other sites More sharing options...
cruiser54 Posted March 24, 2021 Share Posted March 24, 2021 If the PO used the wrong intake gasket, good chance there's a vacuum leak where the intake meets the head. Link to comment Share on other sites More sharing options...
Epplebee Posted March 24, 2021 Author Share Posted March 24, 2021 35 minutes ago, cruiser54 said: If the PO used the wrong intake gasket, good chance there's a vacuum leak where the intake meets the head. Wouldn't that cause a other issues then just stumbling between 1500-2000 rpm though? Link to comment Share on other sites More sharing options...
cruiser54 Posted March 24, 2021 Share Posted March 24, 2021 Not if it's opening from 1500 to 2000 RPM.................. Link to comment Share on other sites More sharing options...
Epplebee Posted March 24, 2021 Author Share Posted March 24, 2021 1 hour ago, cruiser54 said: Not if it's opening from 1500 to 2000 RPM.................. Spoke with the PO, he said that he followed all of your tips to the T, including the intake gasket Link to comment Share on other sites More sharing options...
cruiser54 Posted March 24, 2021 Share Posted March 24, 2021 Have you checked the intake manifold bolts to see if they're loose? Ever spray carb cleaner around potential intake/vacuum leaks at idle? Check the ground at the MAP sensor specifically? Link to comment Share on other sites More sharing options...
Ωhm Posted March 24, 2021 Share Posted March 24, 2021 3 hours ago, Epplebee said: TPS tested good TPS closed throttle voltage is a static test, used for adjusting TPS. TPS might have a flat spot (1500_2000rpms). Dynamic test requires moving TPS slowly between its lower and upper limits looking for any faulty spots. This type of testing would need analog voltmeter. Some DVOM have a BAR meter under the numeric display and read voltage 10 times faster than the numeric display. Could possibly find your flat spot there, if one does exist. Link to comment Share on other sites More sharing options...
Epplebee Posted April 1, 2021 Author Share Posted April 1, 2021 On 3/24/2021 at 7:21 PM, cruiser54 said: Have you checked the intake manifold bolts to see if they're loose? Ever spray carb cleaner around potential intake/vacuum leaks at idle? Check the ground at the MAP sensor specifically? YOU ARE THE MAN CRUISER!!! Only tip the PO didn't do was dizzy indexing. Set the dizzy properly and runs like a top. I want to thank you for your tips because I was going bat $#!& crazy.......once again, you are THE MAN!!!!! Link to comment Share on other sites More sharing options...
cruiser54 Posted April 2, 2021 Share Posted April 2, 2021 4 hours ago, Epplebee said: YOU ARE THE MAN CRUISER!!! Only tip the PO didn't do was dizzy indexing. Set the dizzy properly and runs like a top. I want to thank you for your tips because I was going bat $#!& crazy.......once again, you are THE MAN!!!!! You hung in there!! Congratulations. Link to comment Share on other sites More sharing options...
