Pete M Posted March 2, 2021 Posted March 2, 2021 this stuff? and what was the temp for the oven? for the life of me I can't find that thread.
Tex06 Posted March 9, 2021 Posted March 9, 2021 Or use a clear silicone sealant. Water-proof, clear, and holds up up UV very well.
BeatCJ Posted March 11, 2021 Posted March 11, 2021 Will silicone poison the plastic so clear coat won't stick? Silicone and most solvent based finishes don't play well with each other, I would try to avoid it and choose another adhesive.
Pete M Posted March 11, 2021 Author Posted March 11, 2021 'tis true. silicone doesn't go well with anything. care must be taken.
Tex06 Posted March 15, 2021 Posted March 15, 2021 On 3/10/2021 at 6:30 PM, BeatCJ said: Will silicone poison the plastic so clear coat won't stick? Silicone and most solvent based finishes don't play well with each other, I would try to avoid it and choose another adhesive. You'll definitely have to make sure you don't get it all over everything. Silicone doesn't harden so it works very well in vibration-prone environments. The Oracle stuff is silicone based, not sure what exactly differentiates it from regular black RTV, but it comes with the same precautions (protect any surfaces to be coated later on).
