schardein Posted March 1, 2021 Posted March 1, 2021 I guess little things get me excited. I've had this chrome tailgate handle for a while, but the pass side link retainer broke while I was removing it. Been sitting in my parts cabinet for about a year. Did a little research, turns out the tailgate latch on a Renix era XJ uses the same piece. Scored one today and did a quick swap out. For the record, later XJs use retainers that are all plastic, and I think those would work as well. I was wanting a metal one like original.
eaglescout526 Posted March 1, 2021 Posted March 1, 2021 The metal ones are vastly superior. I had one of the plastic inserts break and I just took a plastic one, cut the hook off and used it to retain the metal one.
schardein Posted March 1, 2021 Author Posted March 1, 2021 7 minutes ago, eaglescout526 said: The metal ones are vastly superior. I had one of the plastic inserts break and I just took a plastic one, cut the hook off and used it to retain the metal one. 8 minutes ago, eaglescout526 said: The metal ones are vastly superior. I had one of the plastic inserts break and I just took a plastic one, cut the hook off and used it to retain the metal one. Brilliant! I mangled the plastic retainer getting the part off the XJ, since I had to hold the gate open with one arm (gas struts were gone). Wasn't worried as I knew the one on the MJ latch was good. But I have extra plastic type retainers and might not have thought to mod them.
ghetdjc320 Posted March 2, 2021 Posted March 2, 2021 Wouldn’t door lock linkage retainers work also? They’re all over the place online and come in metal or plastic
schardein Posted March 2, 2021 Author Posted March 2, 2021 40 minutes ago, ghetdjc320 said: Wouldn’t door lock linkage retainers work also? They’re all over the place online and come in metal or plastic I'd say yes, these are the same thing. I never looked online. Just did a quick search, they are out there but I didn't see an exact match.
