Warren99 Posted February 21, 2021 Posted February 21, 2021 The right turn signal clicks back in place when the wheel is aprx 90 degrees to the right. The left turn signal doesn’t return at all. I’m honestly having a hard time remembering if it ever did, but I do know that I swapped over a different internal piece so I could fit a 3 spoke wheel. Is this a common issue where some little tab or something broke, or should I just open up the steering column
jdog Posted February 21, 2021 Posted February 21, 2021 A little tab broke, you need a turn signal switch
eaglescout526 Posted February 21, 2021 Posted February 21, 2021 When mine had the same issue it was just a little spring on the turn switch itself that was missing.
Warren99 Posted February 21, 2021 Author Posted February 21, 2021 Ok, I’ll look at it when I get a chance. I just hate taking my wheel off bc the only puller I have barely works and is finicky
