Jeff jeeps Posted February 10, 2021 Posted February 10, 2021 Hello I'm just looking for the best advice about installing everything into my Comanche i have everything ready to go in just not sure where to start or what to do first any leads to a forum would be awesome thank you have a wonderful day
jdog Posted February 10, 2021 Posted February 10, 2021 A little more info about what you're starting with and what year is going into it, there's a lot of write up on this particular project here https://comancheclub.com/topic/48710-diy-projects-writeups-master-search-index/
Jeff jeeps Posted February 10, 2021 Author Posted February 10, 2021 1988 jeep Comanche and I'm converting to 97 dash harness gonna have ax15 instead of aw4 ive gotten all the dash mounts out of the Donner I'm mainly concerned about the harness to the tail lights I'm gonna run the 97 harness as far back as I can and mount the gas tank in bed until I get something different just maybe a link to a detailed way of doin the conversion would be awesome
Dzimm Posted February 11, 2021 Posted February 11, 2021 I've linked one of the more detailed projects below. My 97+ build is also linked in my signature below. You have to look through the build thread section for 97+ swaps and you'll find all the info for anything on it. I believe there is info in the Write-ups section as well. As far as the rear harness, I'd recommend retaining the plug block from the rear of the XJ where all the rear harnesses plug into, this rearward is where you'll have to make some harness changes but you can plug the modified harnesses in here. You can take the XJ fuel pump harness and adapt it to work with other fuel pumps. I used a Dodge dakota tank and pump as it fits in the factory fuel tank location under the bed. I made an adapter for the wiring as the plugs are different but the fuel sender signals work with the XJ fuel gauge which is a huge plus for this setup. The taillights I just cut and extended the XJ taillight harness and modified the XJ bulb sockets to fit in the MJ taillights. I feel this is the easiest way to go about it. You could of course do it all custom but that's a lot of work compared to modifying the factory harnesses.
