Just bought a receiver from a 91 XJ. Unfortunately the seller didn't have the bolts/washers for the hitch. Does anyone know the thread pattern, length and how many to use and do I use washers?
Id guess m12. And I'd say 35mm or so...just a guess going off thr mj hitch
Sent from my SM-G973U using Tapatalk
Thank you sir. I'll get a set and confirm the thread pattern
Sent from my SM-G781U using Tapatalk
Actually, to mount thr hitch on your xj you'll need the nut strip for inside the frame...jcr makes them or search xj nut strip.
Sorry, forgot about that
Those would work to install the hitch onto the xj
Xj hitches don't mount to MJs, krustyballer makes a hitch for the mj if you look in the vendor section he has them there.
I think we all wish you had asked before you bought. The XJ hitch mounts to the underside of the "frame" rails, with those nut strips slid in from the back after removing the rear bumper. MJ hitches mount to the sides of the rear frame, using the same mounting points as the bumper mounts.
Yeah I'd wish I would have asked and done my research. I'll have to save up to buy krustys hitch for sure. They look well built.
If ordered this week, I'll knock $15 off.
That goes for anybody else interested too.
I would like to get one if my after market bumper would not interfere with it. You can see the bumper in the pictures of my mj in MJOTM jan21.
Yep, it'll fit that bumper just fine. One of the most common aftermarket bumpers for our trucks
