marcial88 Posted February 7, 2021 Share Posted February 7, 2021 Just bought a receiver from a 91 XJ. Unfortunately the seller didn't have the bolts/washers for the hitch. Does anyone know the thread pattern, length and how many to use and do I use washers? Link to comment Share on other sites More sharing options...
krustyballer16 Posted February 7, 2021 Share Posted February 7, 2021 Id guess m12. And I'd say 35mm or so...just a guess going off thr mj hitchSent from my SM-G973U using Tapatalk Link to comment Share on other sites More sharing options...
marcial88 Posted February 7, 2021 Author Share Posted February 7, 2021 Id guess m12. And I'd say 35mm or so...just a guess going off thr mj hitchSent from my SM-G973U using TapatalkThank you sir. I'll get a set and confirm the thread pattern Sent from my SM-G781U using Tapatalk Link to comment Share on other sites More sharing options...
krustyballer16 Posted February 7, 2021 Share Posted February 7, 2021 Actually, to mount thr hitch on your xj you'll need the nut strip for inside the frame...jcr makes them or search xj nut strip. Sorry, forgot about that Sent from my SM-G973U using Tapatalk Link to comment Share on other sites More sharing options...
marcial88 Posted February 7, 2021 Author Share Posted February 7, 2021 Would this one work? It mentions that its good for XJs but not sure if it will work on MJs. https://www.amazon.com/dp/B00QJANNNQ/ref=cm_sw_r_cp_awdb_imm_t1_JV91C4D0B2FX2WH9RD8H?_encoding=UTF8&psc=1 https://www.jcroffroad.com/product/XJNTSP.html Link to comment Share on other sites More sharing options...
jdog Posted February 7, 2021 Share Posted February 7, 2021 Those would work to install the hitch onto the xj Xj hitches don't mount to MJs, krustyballer makes a hitch for the mj if you look in the vendor section he has them there. Link to comment Share on other sites More sharing options...
krustyballer16 Posted February 7, 2021 Share Posted February 7, 2021 Ooo, ya, an xj hitch won't work on an mj. Thiught you were putting it on an xj. SorryYa. I build mj specific hitchesSent from my SM-G973U using Tapatalk Link to comment Share on other sites More sharing options...
Eagle Posted February 7, 2021 Share Posted February 7, 2021 I think we all wish you had asked before you bought. The XJ hitch mounts to the underside of the "frame" rails, with those nut strips slid in from the back after removing the rear bumper. MJ hitches mount to the sides of the rear frame, using the same mounting points as the bumper mounts. Link to comment Share on other sites More sharing options...
marcial88 Posted February 7, 2021 Author Share Posted February 7, 2021 58 minutes ago, Eagle said: I think we all wish you had asked before you bought. The XJ hitch mounts to the underside of the "frame" rails, with those nut strips slid in from the back after removing the rear bumper. MJ hitches mount to the sides of the rear frame, using the same mounting points as the bumper mounts. Yeah I'd wish I would have asked and done my research. I'll have to save up to buy krustys hitch for sure. They look well built. Link to comment Share on other sites More sharing options...
krustyballer16 Posted February 8, 2021 Share Posted February 8, 2021 Yeah I'd wish I would have asked and done my research. I'll have to save up to buy krustys hitch for sure. They look well built. If ordered this week, I'll knock $15 off. That goes for anybody else interested too. Sent from my SM-G973U using Tapatalk Link to comment Share on other sites More sharing options...
olddude Posted February 8, 2021 Share Posted February 8, 2021 3 hours ago, krustyballer16 said: If ordered this week, I'll knock $15 off. That goes for anybody else interested too. Sent from my SM-G973U using Tapatalk I would like to get one if my after market bumper would not interfere with it. You can see the bumper in the pictures of my mj in MJOTM jan21. Link to comment Share on other sites More sharing options...
krustyballer16 Posted February 8, 2021 Share Posted February 8, 2021 I would like to get one if my after market bumper would not interfere with it. You can see the bumper in the pictures of my mj in MJOTM jan21.Yep, it'll fit that bumper just fine. One of the most common aftermarket bumpers for our trucks Sent from my SM-G973U using Tapatalk Link to comment Share on other sites More sharing options...
