Southpaw Posted January 27, 2021 Share Posted January 27, 2021 will cherokee seats fit the 87 comanche bucket or bench interchange need new interior Link to comment Share on other sites More sharing options...
Dammerung Posted January 27, 2021 Share Posted January 27, 2021 will cherokee seats fit the 87 comanche bucket or bench interchange need new interior Cherokee seats won’t fit, as the floor pan was slightly different. You can cut off the brackets to your bench/buckets and reweld them onSent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Southpaw Posted January 27, 2021 Author Share Posted January 27, 2021 thanks for the info Link to comment Share on other sites More sharing options...
Pete M Posted January 27, 2021 Share Posted January 27, 2021 what cherokee seats exactly? there are different styles used over the years. Link to comment Share on other sites More sharing options...
Eagle Posted January 27, 2021 Share Posted January 27, 2021 1 hour ago, Dammerung said: Cherokee seats won’t fit, as the floor pan was slightly different. You can cut off the brackets to your bench/buckets and reweld them on Sent from my iPhone using Tapatalk No cutting or welding required. Link to comment Share on other sites More sharing options...
Southpaw Posted January 27, 2021 Author Share Posted January 27, 2021 87 comanche 2 wheel drive short bed 4.0is what I'm looking to get interior parts for thanks for responding Link to comment Share on other sites More sharing options...
Southpaw Posted January 27, 2021 Author Share Posted January 27, 2021 15 hours ago, Pete M said: what cherokee seats exactly? there are different styles used over the years. i was looking at 87 cherokee bench seat thanks Link to comment Share on other sites More sharing options...
Pete M Posted January 27, 2021 Share Posted January 27, 2021 2dr XJ seats with the straight sliders are more or less the same as MJ buckets and will go on to your bench floor brackets fairly easily. 4dr XJ seats with the straight slider are also close enough to work, but don't lean forward. any XJ seat with the curved rocking slider will sit you up a couple inches higher than stock MJ buckets but still work. 96+ have a completely different type of assembly underneath and need a bit more fab work. most any junkyard bucket seat from any car can be installed if you can fab up an adapter out of flat stock or tubing. benches too. in the link in my signature you'll find a writeup on using the dakota split bench. Link to comment Share on other sites More sharing options...
Southpaw Posted January 27, 2021 Author Share Posted January 27, 2021 1 hour ago, Pete M said: 2dr XJ seats with the straight sliders are more or less the same as MJ buckets and will go on to your bench floor brackets fairly easily. 4dr XJ seats with the straight slider are also close enough to work, but don't lean forward. any XJ seat with the curved rocking slider will sit you up a couple inches higher than stock MJ buckets but still work. 96+ have a completely different type of assembly underneath and need a bit more fab work. most any junkyard bucket seat from any car can be installed if you can fab up an adapter out of flat stock or tubing. benches too. in the link in my signature you'll find a writeup on using the dakota split bench. thanks i need the mounts also Link to comment Share on other sites More sharing options...
Pete M Posted January 27, 2021 Share Posted January 27, 2021 45 minutes ago, Southpaw said: thanks i need the mounts also the floor mounts? what do you have in it now? bench? Link to comment Share on other sites More sharing options...
Southpaw Posted January 27, 2021 Author Share Posted January 27, 2021 2 minutes ago, Pete M said: the floor mounts? what do you have in it now? bench? nothing in it seats, head liner .door panels all gone they said it came with bench seats Link to comment Share on other sites More sharing options...
Pete M Posted January 27, 2021 Share Posted January 27, 2021 dang. well, check the Venders part of the classifieds to see if Brandon has any new floor brackets left. Link to comment Share on other sites More sharing options...
Southpaw Posted January 27, 2021 Author Share Posted January 27, 2021 7 minutes ago, Pete M said: dang. well, check the Venders part of the classifieds to see if Brandon has any new floor brackets left. thanks 7 minutes ago, Pete M said: dang. well, check the Venders part of the classifieds to see if Brandon has any new floor brackets left. thanks Link to comment Share on other sites More sharing options...
Southpaw Posted January 27, 2021 Author Share Posted January 27, 2021 16 minutes ago, Pete M said: dang. well, check the Venders part of the classifieds to see if Brandon has any new floor brackets left. This is what I have to work with Link to comment Share on other sites More sharing options...
Southpaw Posted January 27, 2021 Author Share Posted January 27, 2021 29 minutes ago, Pete M said: dang. well, check the Venders part of the classifieds to see if Brandon has any new floor brackets left. This is sound like it's more than what I want to tackle I also need an engine rebuild what is a 87 Comanche worth with an Arizona body Link to comment Share on other sites More sharing options...
Pete M Posted January 27, 2021 Share Posted January 27, 2021 well that escalated quickly. what happened to the engine? what are your compression numbers? Link to comment Share on other sites More sharing options...
Pete M Posted January 27, 2021 Share Posted January 27, 2021 Just buy some MJ seats. they go right in. Link to comment Share on other sites More sharing options...
Southpaw Posted January 27, 2021 Author Share Posted January 27, 2021 1 hour ago, Pete M said: well that escalated quickly. what happened to the engine? what are your compression numbers? i bought the truck in az guy pulled head off and just let it sit for 8 years the lady said it ran great just leaked oil 17000miles Link to comment Share on other sites More sharing options...
Southpaw Posted January 27, 2021 Author Share Posted January 27, 2021 1 hour ago, Pete M said: Just buy some MJ seats. they go right in. can't find any Link to comment Share on other sites More sharing options...
JolietJEEP'84 Posted January 27, 2021 Share Posted January 27, 2021 Where are you located? Link to comment Share on other sites More sharing options...
Southpaw Posted January 27, 2021 Author Share Posted January 27, 2021 mi Link to comment Share on other sites More sharing options...
JolietJEEP'84 Posted January 27, 2021 Share Posted January 27, 2021 Michigan is a large state. Near what city? I'm south of Chicago and may have something for you. Link to comment Share on other sites More sharing options...
Southpaw Posted January 27, 2021 Author Share Posted January 27, 2021 ludington Link to comment Share on other sites More sharing options...
Southpaw Posted January 27, 2021 Author Share Posted January 27, 2021 I'm willing to make a road trip Link to comment Share on other sites More sharing options...
JolietJEEP'84 Posted January 27, 2021 Share Posted January 27, 2021 2 minutes ago, Southpaw said: ludington PM sent! Link to comment Share on other sites More sharing options...
