Torq_Shep Posted January 22, 2021 Share Posted January 22, 2021 So I replaced my brake booster in the 1989 and put the brake light switch on the new booster. I think I put it on the way it was supposed to go but it does not work like it should. If I get under the dash and push the switch up or down on the booster to brake pedal mount it will turn on the brake lights but it does not work under normal operation. Is there an adjustment procedure for the AMC style switch? Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 22, 2021 Share Posted January 22, 2021 Not that I have seen. My understanding is it just goes on through the rod that connects to the pedal and booster and it just works. I could be wrong, but I also don’t have an FSM in front of me at the moment. Link to comment Share on other sites More sharing options...
Big Dan Posted January 22, 2021 Share Posted January 22, 2021 It's finicky. It supposed to come from the factory with a spacer, that offsets it correctly, and it's ready to go.If that spacer if worn down some, that may be why you can move it and get brake lights.Potential fix is to line the spacer with something (tape/aluminum foil, similar) to get the offset correct again.There are no true factory adjustment procedures that I'm aware of.I ended up making a bracket and using a normal push style brake switch from a J10. Sent from my Pixel 4 XL using Tapatalk Link to comment Share on other sites More sharing options...
Warren99 Posted January 22, 2021 Share Posted January 22, 2021 1 hour ago, Big Dan said: It's finicky. It supposed to come from the factory with a spacer, that offsets it correctly, and it's ready to go. If that spacer if worn down some, that may be why you can move it and get brake lights. Potential fix is to line the spacer with something (tape/aluminum foil, similar) to get the offset correct again. There are no true factory adjustment procedures that I'm aware of. I ended up making a bracket and using a normal push style brake switch from a J10. Sent from my Pixel 4 XL using Tapatalk I just put a newer brake booster on my 89 and it had a smaller hole so I had to drill it out to fit the brake pedal and switch stuff thru it. Just like this one It was finicky and up or down would make brakes permanently on. You just have to find the center point, then like Big Dan said put electrical tape or something in it. I think I put electrical tape on mine. Link to comment Share on other sites More sharing options...
Torq_Shep Posted January 23, 2021 Author Share Posted January 23, 2021 Got it working with a spacer. Link to comment Share on other sites More sharing options...
Big Dan Posted January 23, 2021 Share Posted January 23, 2021 Got it working with a spacer.Good deal! Sent from my Pixel 4 XL using Tapatalk Link to comment Share on other sites More sharing options...
