knever3 Posted December 27, 2020 Share Posted December 27, 2020 I want to know if anyone knows the thread size and pitch to put regular nuts on the back wall studs. I am aware they use steel speed nuts that do not have actual threads. Sent from my SM-G960U1 using Tapatalk Link to comment Share on other sites More sharing options...
AZJeff Posted December 28, 2020 Share Posted December 28, 2020 19 hours ago, knever3 said: I want to know if anyone knows the thread size and pitch to put regular nuts on the back wall studs. I am aware they use steel speed nuts that do not have actual threads. Sent from my SM-G960U1 using Tapatalk Those nuts cut their own threads as they are installed the first time onto the smooth stud that is welded to the cab. If you want to use conventional nuts, you will need to thread those studs with a corresponding die. That may prove difficult, since the lead-in on a die won't allow you to create full-depth threads for more than 1 or 2 turns. Unless your studs are really trashed, I would use the OEM type speed nut. Alternatively, you could use a push on clip like this: Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 28, 2020 Share Posted December 28, 2020 You can get a box of those nuts in various sizes from Amazon. They’re like nameplate nuts but I forget their actual name. Link to comment Share on other sites More sharing options...
Jesse J Posted January 4, 2021 Share Posted January 4, 2021 On 12/28/2020 at 8:10 AM, AZJeff said: Those nuts cut their own threads as they are installed the first time onto the smooth stud that is welded to the cab. If you want to use conventional nuts, you will need to thread those studs with a corresponding die. That may prove difficult, since the lead-in on a die won't allow you to create full-depth threads for more than 1 or 2 turns. Unless your studs are really trashed, I would use the OEM type speed nut. Alternatively, you could use a push on clip like this: what size push clip? Link to comment Share on other sites More sharing options...
AZJeff Posted January 4, 2021 Share Posted January 4, 2021 14 hours ago, Jesse J said: what size push clip? You would need to measure the diameter of the stud and get a clip whose hole is a slight interference fit onto the stud. My local hardware store actually stocks these kinds of clips, so maybe you can find one nearby that does the same. Otherwise....Amazon is your friend. Link to comment Share on other sites More sharing options...
Jesse J Posted January 4, 2021 Share Posted January 4, 2021 4 minutes ago, AZJeff said: You would need to measure the diameter of the stud and get a clip whose hole is a slight interference fit onto the stud. My local hardware store actually stocks these kinds of clips, so maybe you can find one nearby that does the same. Otherwise....Amazon is your friend. ok will do thanks Link to comment Share on other sites More sharing options...
