eaglescout526 Posted December 23, 2020 Share Posted December 23, 2020 Alright guys, Aside from what the wiring harness tag would say, does anyone have any idea how to identify which tank the sending units go to? The catalog shows me that 18 gallon and 23.5 gallon sending units are the same but 16 gallon is different. Are there any physical characteristics about them that sets them apart? Link to comment Share on other sites More sharing options...
WahooSteeler Posted December 23, 2020 Share Posted December 23, 2020 IIRC, the 16 gal tank is actually deeper than the 18 & 23 so the FSU is longer. I seem to recall finding pics and dimensions of a 16gal tank and it is more square. The 18 &23 are the same depth, hence the same FSU's, the 23 gal is just longer. Not sure if this helps........... Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 23, 2020 Author Share Posted December 23, 2020 This might actually help. I will post the pics of the three I have. But they look pretty similar to me. Maybe I should rotate them the other way? Link to comment Share on other sites More sharing options...
WahooSteeler Posted December 23, 2020 Share Posted December 23, 2020 Did some quick research, I got some info backwards I think. The 16 gal tank is long and shallow, so the FSU from a 16gal would not work in a 23gal. The 18gal is the one that is short and deep with the FSU being interchangeable with the 23.5gal tank. To my eyes, the last one in your pics looks shorter, particularly after the bend down to the pickup. Maybe measure them compared to the pic I posted. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 23, 2020 Author Share Posted December 23, 2020 Sounds good! Appreciate the info Wahoo! Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 11, 2021 Author Share Posted January 11, 2021 Any other key identifiers? I only ask because they all measure the same and one has writing on it denoting from a 90 LWB but that doesnt help by much. Maybe an Ωhm test even though all Renix SU's are 0-88. Maybe I could plug them in and see which ones will read past full and at full. Link to comment Share on other sites More sharing options...
Limeyjeeper Posted January 11, 2021 Share Posted January 11, 2021 HO sender units read 0 ohms full to 105 empty. Renix 85 Full to 0 empty. So they work exactly opposite. Also all HO fuel sending units were the same I believe 52017559. Except the Diesel. When I did the LS and swapped the HO Instrument cluster so I could use a 120mph Speedometer I had to use a Pre 91 fuel gauge or it read wrong. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 11, 2021 Author Share Posted January 11, 2021 I can’t imagine the three I have are HO but to be fair, whom I got them from couldn’t remember because he pulled them sooo long ago so I’ll check the ohms. I compared them all to a NOS 23gal SU I had and they all still looked them same in terms of angle and length so I’m not exactly sure. I don’t want to hang on to these if someone needs one but I also don’t want to sell the wrong one to someone. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 14, 2021 Author Share Posted January 14, 2021 When I get to my 23 gallon tank swap, I’ll look at my 16 gallon unit and compare the three to that one. I have an NOS 23 gallon unit that is probably from 86 as it holds a fuel pump but the pipes point straight out. I’ll figure it out soon. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 14, 2021 Author Share Posted January 14, 2021 On 1/14/2021 at 10:10 PM, saveevryjp1998 said: If it's factory straight piped, no doubt for sure it's an 86 or older, that I know. I still have a dozen or 2 senders yet. I've pulled over a hundred I think lol. You use to be able to order tank strap kits for lwb Mj at the zone for less than swb. I always ordered lwb kits for short and saved the extra strap since they are all identical. Short only has 2 is the difference. Expand Neat! I figured it was 86 as it looked different than what I have normally seen and the only PN on it is on the wiring harness as a tag and it says 23.5gal on it. Thats good info to know. Hopefully I will find out the difference and be able to sell the three units as I don't want to hoard them when someone can use them. Link to comment Share on other sites More sharing options...
Limeyjeeper Posted January 15, 2021 Share Posted January 15, 2021 On 1/11/2021 at 1:27 AM, eaglescout526 said: I can’t imagine the three I have are HO but to be fair, whom I got them from couldn’t remember because he pulled them sooo long ago so I’ll check the ohms. I compared them all to a NOS 23gal SU I had and they all still looked them same in terms of angle and length so I’m not exactly sure. I don’t want to hang on to these if someone needs one but I also don’t want to sell the wrong one to someone. Expand An ohm meter on the sender unit is the easiest way to tell if they are HO or not Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 3, 2021 Author Share Posted April 3, 2021 SOLVED!! 16 gallons have a short lever arm! Thats why the gauge can go past full! So 18 and 23 share the same sending unit according to the catalog which means I can now sell those three sending units! Look at that arm! Its like a babys arm compared to the ones I have. Link to comment Share on other sites More sharing options...
jdog Posted April 3, 2021 Share Posted April 3, 2021 the hammer looks smaller Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 3, 2021 Author Share Posted April 3, 2021 On 4/3/2021 at 3:33 AM, jdog said: the hammer looks smaller Expand Thats the fathers garage special lol. That hammer has actually proven mighty useful for its stature. What happened was many years ago, my dad was using it and the head fell off and the wood split. So he cut it down and whittled it to fit the head. Link to comment Share on other sites More sharing options...
jdog Posted April 3, 2021 Share Posted April 3, 2021 On 4/3/2021 at 3:35 AM, eaglescout526 said: Thats the fathers garage special lol. That hammer has actually proven mighty useful for its stature. What happened was many years ago, my dad was using it and the head fell off and the wood split. So he cut it down and whittled it to fit the head. Expand ah, those are some of the better hammers Link to comment Share on other sites More sharing options...
