1986 2.8l V6 Missing
Hey all, I have searched around on these forums for quite a bit looking for a solution to a couple problems associated with my 2.8l. Engine was completely rebuilt, shaved cams, new bearings new rods, spark plugs, everything. Yet my engine continues to miss at idle speed. It gets worse when it is shifted into reverse, but it never kills the engine. Increasing the idle speed makes the engine sound better, but it still misses. It is inconsistent as well which is part of the confusing part. Any help would be greatly appreciated.
8 hours ago, coheed said:
I know for a fact one of the manuals I have has the firing order of the 2.8 listed wrong cause I had the same issue.
by how much is wrong? in my experience even having 2 wires swapped can lead to a no start to a run like crap situation
i’ve had the same experience. i’m almost positive they are correct. i can drive it on highway speeds and the engine starts and stays running but it continues to miss
8 hours ago, 89 MJ said:
Yank it out and swap in a different motor. :peep:
i would love to but as of right now it’s too expensive and would be too much work. i am moving out of state in less than a month and need this truck running to take with me.
9 hours ago, coheed said:
I know it sounds dumb but recheck your firing order. I know for a fact one of the manuals I have has the firing order of the 2.8 listed wrong cause I had the same issue.
isn’t firing order on this truck just 123456
