*X1 TRIM STYLE X1 - CLOTH BENCH
-H9
131 Zone 31-Boston
1AA U.S. Dealer Retail
5AM
5KM
ALM
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
CSR Passenger Assist Handles
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHN Command-Trac Part Time 4WD System
DHT  ,Shift-on-the-Fly,P/Time T/Case
DJH 230MM Front Axle
DMD 3.55 Rear Axle Ratio
DRJ Dana M235 Wide Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEC Front Left Side Sliding Window
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HCD Do Not Use - See HCA
JAA Instrument Panel
JAZ DO NOT USE - See JP, KA classes
JBD BEZEL-I/PANEL CLUSTER - BRIGHT
JCA 85 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
JKB
K2X STRIPE/BADGE/MOLDING/COLOR
K3D STRIPE/BADGE/MOLDING/COLOR
KKG
LAF Seat Belt Alert-Driver Seat only
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black rear Bumper
MDA Front License Plate Bracket
MFG Body Color Headlamp Bezels
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF5 Fuel Tank - 23 Gallon
PS3 DOVER GREY MET CL CT PRIMARY PAINT - HS3
QS3 DOVER GREY MET C C SECONDARY PAINT - HS3
RAA All Radio Equipped Vehicles
RAB AM/FM Radio
RCD 4 Speakers
SBA Power Steering
SCE  Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TAD HIGHWAY TREAD
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TPF P205/75R15 BSW All Season Tires
WJD 15X7.0 Styled Steel Wheels
XBS Pickup Box
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z66 Left Front Group XV
Z85 Right Front Spring Group XIV
Build date 5/12/89
Body code JM62
-H9
131 Zone 31-Boston
5AM
5KM
ALM
APA Monotone Paint
BCX
EAA All Engines
JJA Cigar Lighter
JKB
KKG
LBC Glove Box Lamp
MMG Belt Moldings
RAB AM/FM Radio
RCD 4 Speakers
SBA Power Steering
TAA All Tires
TAD HIGHWAY TREAD
XBS Pickup Box
Build date 5/12/89
Body code JM62
Thank you
  • 4 months later...
