1J7FJ26S5NL107527
Tex06
Wow, I had thought I did this years ago when we first started tracking VINs....
1992, Jeep, Comanche Pioneer.
4.0L/ AX-15 / NP-231 / Dana 30 / Dana 44 / LWB
Build date: Unknown
Current Location: New Orleans, La
Status: Daily Driver (238k and counting!)
Notes: Bench Seat, Vinyl Interior, Floor Shift, Originally Hunter Green Exterior and Tan Interior.
Current owner: Me.
Body: jl62
Build: 9/13/91
*C1 DESCRIPTION NOT AVAILABLE -Y6   ALAP
BARP 90 Amp Alternator BCDP Maintenance Free Battery CBAP Straight Back Bench Seat
CKAP Carpets - Floor and Cargo Area DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission
DRKP Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle ERH 4.0L I6 Power Tech Engine
GFD Rear Sliding Window GRZP Left Remote Mirror GSZP Right Remote Control Mirror
GTZP Manual Remote Mirrors HAA Air Conditioning JAYP DO NOT USE - See JP, KA classes
JHAP Var Intermittent Windshield Wipers JJAP Cigar Lighter KERP DESCRIPTION NOT AVAILABLE
MBJP Black Front Bumper MDAP Front License Plate Bracket MHAP Black Windshield Moldings
MMKP Lower Grille Surround-Painted Silver NAE California Emissions PG5 Hunter Green Metallic
RAAC All Radio Equipped Vehicles RAFP AM/FM Cassette Radio RCDP 4 Speakers
SCGP Leather Wrapped Steering Wheel SUA Tilt Steering Column TBB Full Size Spare Tire
TMWP  Tires TZHP Michelin Brand Tires WJHP 15X7 Aluminum Wheels
WLZC All Aluminum Wheels YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I
Z66P Left Front Group XV Z85P Right Front Spring Group XIV 2TCA Customer Preferred Package 2TC
25C Customer Preferred Package 25C 3VNA Customer Preferred Discount 4BJA Wheel Credit
APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes CUMS Mini Floor Console
DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMMS 3.07 Rear Axle Ratio
GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass
GEHS Fixed Door Vent Glass JCAS 85 MPH Primary Speedometer KWRS STRIPE/BADGE/MOLDING/COLOR
K3ZS STRIPE/BADGE/MOLDING/COLOR LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp
LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille
MMCS Rear Door Solid Window Insert MMGS Belt Moldings NBKS EVAP Control System
NF5S 23 Gallon Fuel Tank QG5S Hunter Green Metallic Clear Coat SBAS Power Steering
SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBMS Tire Carrier Winch
XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating
1AAS U.S. Dealer Retail 171S Zone 71-Los Angeles
2 minutes ago, 89 MJ said:
Let's see some pictures of this thing.
You know, I used a have a whole pile of them on here....guess the site has been updated since I was last really active. Lemme see what I can find
22 hours ago, 89 MJ said:
Green HO Metric Ton with a 5 speed and a topper. :drool: :drool: :drool:
Yup. Worst part is, I stumbled onto this thing by complete accident. Guy had it and his gf didn't like diving stick....so I traded a 94 BMW 740 (that I hated) for it. I paid less for this than most people do for their non-drivers....but I do love this damn thing!
On 10/23/2020 at 6:30 PM, jdog said:
correct and edited, my fault
No worries, jdog, we appreciate all the work you do around here.
On a slightly different note, is there a listing of all the available options somewhere? I looked for a sticky and didn't see one, wasn't exactly sure how to search for it without pulling up every post from the registry.
I'm attaching an Excel file I put together from an '89 bulid sheet Pete found and from the salesforce pdf eaglescout526 has.
If you filter on source you can see which codes are from which source, I don't think the salesforce codes are completly accurate.
There is also this on page 3 half way down from the 87 accessories guide.
Decoding_Combined.xlsx
  • 3 months later...
