Floor to column shift
I would like to put my bench seat back in my 86 Comanche. Move the shifter from the floor to the column.
I have already obtained the micro console. ( I guess that is what it is called. Not the mini.)
Column shift with tilt. (I disassembled cleaned and painted to match.)
Instrument cluster with gear indicator. (Going to try to modify old tach to display gear selected. And use full gauges.)
Column shift cable.
I have not had any luck finding how to attach cable to brake pedal assembly. Is it a separate bracket that bolts to the assembly?
Is it a special brake pedal assembly? Does anyone have any pictures? Thanks for any help. Jim
I saw someone cut two clusters apart and modified them so that he had the tach and shift indicator. He was in one of the Comanche FB groups. I think he just removed the shift indicator from one of the clusters and put it in the other, but do not remember 100%. I'll post a picture if I can find one. I know @Pete M is in many of the MJ groups on FB. Maybe he would remember.
