So it rained pretty hard the last 2 nights and now I came out to my jeep with window all wet passanger side carpet with little puddles and the head liner is pretty wet in some areas but I'm not sure if that's just from moisture in the cab or not. Any tips this time what it could be??
2 hours ago, Pete M said:
is your cowl drain clear?
yes they are i blasted them out. alot of the water was draining through the cowl and onto the atenna wire and then dumping right into the cab. but even with the antenna boot back on there there is still water dripping from behind the dash
4 minutes ago, Pete M said:
ahh, the joys of old Jeeps. :(
have you replaced the HVAC seal?
nope i was going to take the dash off though and replace the ac evap and the heater core and see if that did anything. what is the hvac seal?
30 minutes ago, Pete M said:
the foam bit that seals around the hole where the hvac assembly goes through the firewall
Ohh ok is ther somewhere i can buy that
