Davidsamplesmjjr Posted August 29, 2020 Share Posted August 29, 2020 I bought a jeep Comanche mj and was wondering if i could swap out the gauge cluster with a Cherokee does anyone know what model i should use?? ps. jeep Comanche eliminator 4wd Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 29, 2020 Share Posted August 29, 2020 For the most part you can swap with gauge clusters from the same or similar years. 91 and up is what I’m most familiar with and the gauge clusters are interchangeable with XJ 91-95. Pre 91 was the Renix years and this site is full of Renix experts who can say for sure but I believe they also swap across the years 90 and earlier. Link to comment Share on other sites More sharing options...
87MJTIM Posted August 29, 2020 Share Posted August 29, 2020 86-early 87 uses one type of speedometer connector. mid 87 to 90 used a different type of connector. I believe the wire connectors are the same 86 to 90 91+ is HO and all electronic Link to comment Share on other sites More sharing options...
cruiser54 Posted August 29, 2020 Share Posted August 29, 2020 6 hours ago, Davidsamplesmjjr said: I bought a jeep Comanche mj and was wondering if i could swap out the gauge cluster with a Cherokee does anyone know what model i should use?? ps. jeep Comanche eliminator 4wd We need to know what YOU have in order to answer your question accurately........ Link to comment Share on other sites More sharing options...
