Nothing in the store fit the clips I have, didnt measure the thread but it seems to be coarser than 6-32 but about that size. May be metric but none of the std metric stuff fit. so perhaps its not 0.7 thread pitch or maybe its a M3.5
long story short...if you have extra taillight hardware, i'd be stoked to have the factory stuff.
Here's the part number for the clip. Ill try to look it up later in my Mopar screws and bolts book for specifics. Otherwise theres 5 of those clips left in the US.
2 hours ago, ghetdjc320 said:
I used an off the shelf clip with a stainless socket head screw and it’s a perfect fit
Thanks Ghet, where did you find clips? I searched Summit racing and the local hardware didnt find anything decent.
Fastenal has them but they are also in the hardware section of pretty much any auto parts store. Just keep in mind that it’s best to use a screw/bolt with a flat shoulder. Anything with a angled shoulder can crack the plastic lens very easily. I’d start by finding the best fitting fastener and then find the appropriate sized nut/clip. Socket head bolts worked well for me. Most parts stores refer to the clips as “speed nuts”
16 hours ago, eaglescout526 said:
34201265- 1/4" thread diameter, .76"long, .53" wide, .35" from center hole to edge, does not list thread pitch but its made of spring steel and is coated in zinc.
hey eagle, thanks for checking. NO way these are 1/4" though.
Who knows, I was going off of what the book said, I should go back and reread what the symbol means for what the 1/4" is under. At least I thought it was diameter but I could be wrong.
Happy to help though.
On 9/10/2020 at 12:25 PM, Oizarod115 said:
if anyone finds this thread searching, the taillight screws are a #7 sheet metal screw. Finally found some at a better hardware store
you should add this find to the nut/bolt thread!  :L:  it's in the link in my sig.
