Ford 8.8 VS Dana 44?
IIRC, depending on year the Waggy and Scout are the correct width.. but there are other issues with each.
1) Scout is overall kinda funky and you cannot use front axle as is, the caster is set way off for Jeep use. One good thing is the 5 on 5.5 lug spacing.
2) Waggy is a good strong swap, BUT uses the 6on 6.5 lug spacing. Also requires some swaping with CJ parts to get a no nonsence set up for the front. One down side...usually CRAPPY 27? gearing.
CW
  • Replies 52
