1jtmw6456jt197120
RealStoryCory
88 Jeep Comanche Eliminator Short Bed 4.0 manual with 188010 miles.
4.0 with AX15 and 231 transfer case. Dana 30 front and Dana 35 rear axle.
Resides in US Lakeview Oregon.
This is currently my daily driver and trail rig. It runs and drives great after all of the work I put into it. Still updating and restoring what I can.
Here is what has been done:
Dana 30 front axel
Dana 35 rear axel
Replaced peugeot transmission with AX15 and converted to 4x4 with NP231 transfer case
Bluetooth sound system w/8" sub
Replaced slave cylinder
Replaced clutch master cylinder and hydrolyc hose
Replaced rear main seal
Replaced u-joints
Replaced throttle position sensor
Replaced throttle body
Replaced clutch and pressure plate
Replaced starter
Replaced harmonic balancer
Replaced All ground wires and connections as well as battery cables and terminals
Replaced air filter with high flow "Green" filter
New fuel filter
Installed 4 hole Volvo injectors
It is straight piped with knock off flow master muffler.
New black 15" steel wheels
Light harness from K Suspension
Halogen light conversion with Sylvania bulbs
All gauges, lights, and electrical work.
Have parts and need to install:
ECU from a 91 Jeep XJ
New Power steering pump
I need:
Front driver bucket seat with manual slider
Seat belt buckle (driver)
Window crank (grey)
Sun visors (grey)
Rear bumper
Lund sun visor (in time)
build date 5/3/88
body: TS61
*Q7 Cloth Low-Back Bucket Seats -SA Charcoal AGD
APA Monotone Paint BCQ 750 Amp Maintenance Free Battery CAC Low Back Bucket Seats
CGW   CKA Carpets - Floor and Cargo Area CUF Full Length Floor Console
DDJ DESCRIPTION NOT AVAILABLE ERB  4.0L I6 MPI Engine GAC Tinted Glass Windows
GFD Rear Sliding Window GSC Right Black Mirror HAA Air Conditioning
JFH Tachometer JGB Digital Clock JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter K60 STRIPE/BADGE/MOLDING LAP Shift Indicator Warning Lamp
LMA Halogen Headlamps LNJ Front Fog Lamps MBJ Black  Front Bumper
MCA front bumper guards MCB   MDA Front License Plate Bracket
NAA Federal Emissions NHQ Transmission Heater PX6 Paint code
QX6 Paint Code RAB AM/FM Radio SBA Power Steering
SCE  Wrapped Steering Wheel SUA Tilt Steering Column TBG Compact Spare Tire
WJH 15X7 Aluminum Wheels 3LY DESCRIPTION NOT AVAILABLE
  • 7 months later...
