RealStoryCory
    Southern Oregon
RealStoryCory's Achievements
  1. 88 Jeep Comanche Eliminator Short Bed 4.0 manual with 188010 miles. 4.0 with AX15 and 231 transfer case. Dana 30 front and Dana 35 rear axle. Resides in US Lakeview Oregon. This is currently my daily driver and trail rig. It runs and drives great after all of the work I put into it. Still updating and restoring what I can. Here is what has been done: Dana 30 front axel Dana 35 rear axel Replaced peugeot transmission with AX15 and converted to 4x4 with NP231 transfer case Bluetooth sound system w/8" sub Replaced slave cylinder Replaced clutch master cylinder and hydrolyc hose Replaced rear main seal Replaced u-joints Replaced throttle position sensor Replaced throttle body Replaced clutch and pressure plate Replaced starter Replaced harmonic balancer Replaced All ground wires and connections as well as battery cables and terminals Replaced air filter with high flow "Green" filter New fuel filter Installed 4 hole Volvo injectors It is straight piped with knock off flow master muffler. New black 15" steel wheels Light harness from K Suspension Halogen light conversion with Sylvania bulbs All gauges, lights, and electrical work. Have parts and need to install: ECU from a 91 Jeep XJ New Power steering pump I need: Front driver bucket seat with manual slider Seat belt buckle (driver) Window crank (grey) Sun visors (grey) Rear bumper Lund sun visor (in time)
