zomeizter Posted July 26, 2020 Posted July 26, 2020 Just picked these up for cheap, the Jeep set is 17" and the aftermarket ones are 16", these should fit the 'manche right?
Pete M Posted July 26, 2020 Posted July 26, 2020 with spacer adapters. the 17s are a 5 on 5" bolt pattern (MJs are 5 on 4.5") no idea what the 16s are.
Crash Posted July 26, 2020 Posted July 26, 2020 I run the JK wheels on my XJ and MJ. I have the Synergy wheel adapters.
zomeizter Posted July 29, 2020 Author Posted July 29, 2020 On 7/26/2020 at 6:08 PM, Crash said: I run the JK wheels on my XJ and MJ. I have the Synergy wheel adapters. Any dislikes with them? You running one inch spacers I presume?
Crash Posted July 29, 2020 Posted July 29, 2020 Not one bit. They are 1.5 inch. Hubcentric.Worth the money. The JK wheels have more BS than stock XJ/MJ so that helps also considering they are wider wheels too. I think they still have "the look" that works for our vehicles. And also, tire options are more plentiful and mostly less expensive. Than comparable 15/16 dia. Synergy/Poly Performance is a local company for me. Any dislikes with them? You running one inch spacers I presume?
75sv1 Posted July 29, 2020 Posted July 29, 2020 I'm running JK or WJ rims on one of my XJs. Spacers in the rear on a Ford 8.8. The front I did the WJ Big Brake upgrade and used a hub bearing for a WJ. I do have plans to ditch the spacer in the rear.
zomeizter Posted August 1, 2020 Author Posted August 1, 2020 I do like the "sexy look" these wheels give the MJs and XJs I've seen around the area, I plan on wrapping mine with some 33" A/Ts once the lift is installed, shooting for end of summer...
