Hayden 3680 electric fan
What size fuse should i use inline? Simple ground to battery ground, positive coming from battery with fuse holder inline and a switch by the grill? It blew a 10 amp fuse thanks guys
1989 4.0
Renix
Scratchy Ba/10
2wd
Stock
Short bed base
The fan specification should tell you the current draw or the power draw (in watts).  Take the wattage and divide by twelve (battery voltage) to determine current draw.
Caution—startup surge current can be much higher than steady state current.  Take the steady state current and add 25-30% to that when selecting a fuse.
actually, I prefer self-resetting circuit breakers over fuses for cooling fans.  Nothing sucks more than to be stuck by the side of the road because your fan won’t run because of a 25 cent fuse That failed due to fatigue.
If this is the fan....
https://www.summitracing.com/parts/hda-3680
It says it would only have a 8.8 amp draw.
If you blew a 10 amp fuse why not try just going up to a 15 and see if that is enough
I will be trying that today thank you. Hopefully this helps with little heat at idle
1989 4.0
Renix
Scratchy Ba/10
2wd
Stock
Short bed base
An important aside to this: What size wires are you running? Don't up the fuse rating until you know FOR SURE that your wires can handle the load. Asking for a bonfire if this gets messed up.
And my apologies if you already thought of this. I felt it had to be said, just in case.
VERY good point.   If you put in a large fuse, yet use (relatively) small guage wires, you wind up using the wires as the fuse element.
The wires are 12 gauge, i am using a 15amp fuse now and has not blown. Do y’all think maybe i should use bigger wires?
1989 4.0
Renix
Scratchy Ba/10
2wd
Stock
Short bed base
Let’s go back to specifications—what is the STEADY STATE draw of this fan you have chosen?
Then add 20% for start up surge current to figure out peak current.
Now how long are the wires from the 12v source to the fan motor?
Now figure out the voltage drop for a given wire gauge and wire length using the below simple calculator:
https://www.rapidtables.com/calc/wire/voltage-drop-calculator.html
you want your voltage drop to be 0.25vdc or less, so adjust your wire gauge accordingly.
I think ive got this in here right
1989 4.0
Renix
Scratchy Ba/10
2wd
Stock
Short bed base
