Almost finished up! Just got the ski running today and will be finishing the seat and trim tomorrow. Need to move back to the MJ and take care of a hydroboost swap next
  • 5 months later...
Audio system added, complete upgraded fuel system. Deatshwerks STI pump, Russel fuel check valve, and fuel lab adjustable FPR. Just got a set of injectors back from the rebuilders also and had them all flow matched and rebuilt. New skat track impeller and some pump mods happening next.
10 hours ago, Jesse J said:
that thing is so cool. you gotta build a matching trailer so you can tow it with your truck
That would be cool but I can’t do much paint wise with a trailer that is metal and get submerged in salt water. Rust is such a constant battle :fistshake2:
color matched underliner
Doesn’t stick well to galvanized steel plus it’s tough to repair. It will still just rust underneath the liner. Gold galvanizing compound is what I use for touch ups and it really does hold up to the salt very well. But yeah, it would be cool if it matched. Maybe a matching tool box for it.
ok be lame:shaking: I am joking. that sucks wouldve been sick
Keep in mind that with salt water I actually have seen aluminum rust though. It’s crazy, I never thought it would do that. Being here I’ve learned of the various grades of stainless steel and the different processes for keeping things from rusting. Galvanic corrosion is also crazy. Stainless bolts in aluminum etc. If I could have a whole aluminum frame made and then have it anodized with a specific color that’s probably the only thing that would last semi-permanently. Epoxy paint holds up fairly well too I’ve noticed.
2 hours ago, Jesse J said:
all I hear is stainless trailer. box it all so water can't get in
Stainless still rusts. It would need to be at least 316 stainless and would need to be a c channel design so it doesn’t trap any water. Thousands and thousands for no real gain
I was joking lol
