Tilt Column in Black
TheJeepNut
Thought I'd ask here to see if someone has a nice Black one for my #24.
The column in it is not tilt and it sure does make it nice when on longer drives to be able to adjust that once in a while.
I plan to spend a lot of time driving it once done...  :driving:
The wheel doesn't matter, I've got a newish one that looks really good.   Stupid mice ate mine up... :fistshake2:
Ignition type changed in 91. You may be able to swap a 90 down ignition cylinder into a 91 or newer column, but I don't think the older columns have the provisions for the newer ignition cylinder.
Old style are retained by a screw. New style are retained by a spring loaded bar.
