billyblankss Posted June 23, 2020 Author Share Posted June 23, 2020 3 minutes ago, DirtyComanche said: Buy an aftermarket track bar and bracket. Reusing the stock bracket is not worth doing. The stock setup works fine in a stock truck, but it does not hold up long term with larger tires and lift. As a FYI the new track bar you bought likely won't fit the bracket you have either. They changed the size of the taper of the TRE type joint in 91~ (or something) and almost all of the aftermarket ones do not fit the old style bracket without reaming it out with the correct taper reamer. Or maybe it was earlier than that. I don't remember, like I said it's not a good setup anyways. That Iron Rock track bar and bracket isn't a bad deal at $210. The comparable RE one (RE1660 and RE1665, since they sell it as two parts) is $260. Most of the steering upgrades sold for the XJ/MJ are hack and I would not recommend them. Depending how much if you have just going with the V8 ZJ/late model XJ parts and flipping the driver's side tie rod is an inexpensive and reliable option. This is good advice. The only thing i wasn't sure about was going from an articulating end joint / heim joint to a double shear setup would make it difficult to install or ride differently. But it looks like I'm in for 210. Or, rusty's has one with a frame stiffener as well for 220: https://www.rustysoffroad.com/rusty-s-track-bar-hd-track-bar-package-xj.html Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 23, 2020 Share Posted June 23, 2020 5 minutes ago, billyblankss said: This is good advice. The only thing i wasn't sure about was going from an articulating end joint / heim joint to a double shear setup would make it difficult to install or ride differently. But it looks like I'm in for 210. Or, rusty's has one with a frame stiffener as well for 220: https://www.rustysoffroad.com/rusty-s-track-bar-hd-track-bar-package-xj.html That "frame stiffener" isn't worth the $10. Link to comment Share on other sites More sharing options...
thecodemonk Posted June 23, 2020 Share Posted June 23, 2020 Front reinforcement is nice as some support for the track bar mount does help it resist working it's way loose...the one pictured on Rusty's looks a bit flimsy, however and I'm not sure I'd count on it. I used Full Traction's kit on the front of my XJ and it was solid once I got the brace on (it always tried to work it's way loose without the cross brace). It worked well. I have the TnT track bar kit on my MJ currently and am happy with it. Iron Rock OffRoad's kit looks good too and I'm happy with their 3-link kit, so I would assume their track bar setup would be similarly good quality. Link to comment Share on other sites More sharing options...
billyblankss Posted June 23, 2020 Author Share Posted June 23, 2020 Thanks for all the advice. I ended up buying the Iron Rock Offroad one that was linked here. I thought about the Rustys kit but they wanted 83 bucks for shipping... just crazy. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted June 23, 2020 Share Posted June 23, 2020 Good to hear, I've installed 3 IRO trackbar kits so far and have had great results from all of them. Link to comment Share on other sites More sharing options...
