500 MJ Posted June 20, 2020 Share Posted June 20, 2020 Junkyard truck that I came across yesterday while traveling in northern IL. This truck is located at 3B’s Auto Salvage in Davis Junction IL. The truck broke in half when it arrived at the yard about a month ago so the yard crew is using what is left of the bed as a sorting bin for final scrapping out of other carcasses... This is a pull it yourself friendly yard. It seems this yard cycles their inventory quite often, I don’t think this truck will be around at this time next year. At least not the bed. I took the radio, pass mirror, drivers tail light (pass tail already crunched), usable rear bumper parts, headliner and badges from the truck. The fuel tank was long gone, no sending unit available. Link to comment Share on other sites More sharing options...
500 MJ Posted June 20, 2020 Author Share Posted June 20, 2020 @Oizarod115 I just realized this truck has the trans tunnel plate you are looking for. If you can’t get it elsewhere it might be worth your time to call up the yard and see if they will pull it and ship it for you... it’ll probably have some rust on it judging by the rest of how this truck was. sorry I didn’t put 2 and 2 together earlier today and nab it while I was right there... Link to comment Share on other sites More sharing options...
Oizarod115 Posted June 21, 2020 Share Posted June 21, 2020 Thanks Brent, another member was potentially going to pull one for me this weekend but if that doesn’t work out I’ll try here! @500 MJ Link to comment Share on other sites More sharing options...
fiatslug87 Posted June 24, 2020 Share Posted June 24, 2020 Build sheet please. Link to comment Share on other sites More sharing options...
jdog Posted June 24, 2020 Share Posted June 24, 2020 body code tl62 build date 8/22/91 APAS-Monotone Paint BGAS-Power Front Disc/Rear Drum Brakes DGSS-4-Speed Automatic AW4 Transmission DHAS-Lock-Up Torque Converter DMDS-3.55 Rear Axle Ratio GACS-Tinted Glass Windows GBBS-Tinted Windshield Glass GCBS-Front Door Tinted Glass GEHS-Fixed Door Vent Glass JAZS-DO NOT USE - See JP, KA classes JCAS-85 MPH Primary Speedometer KWRS-STRIPE/BADGE/MOLDING/COLOR K3ZS-STRIPE/BADGE/MOLDING/COLOR LBCS-Glove Box Lamp LMAS-Halogen Headlamps MB1S-Black Front Bumper MFFS-Black Grille MMCS-Rear Door Solid Window Insert MMGS-Belt Moldings NAAS-Federal Emissions NBKS-EVAP Control System NF5S-23 Gallon Fuel Tank QW7S-Bright White Clear Coat TBMS-Tire Carrier Winch XBSS-Pickup Box YAAS-Build To U.S. Mkt. Specifications 1AAS-U.S. Dealer Retail 151S-Zone 51-Chicago *C1-DESCRIPTION NOT AVAILABLE -SA-Charcoal ALAP- Decor Group BARP-90 Amp Alternator BCDP-500 Amp Maintenance Free Battery CBAP-Straight Back Bench Seat CKAP-Carpets - Floor and Cargo Area DGB-All 4-Speed Automatic Transmissions DHTP-Elec,Shift-on-the-Fly,P/Time T/Case DRKP-Dana 44/226MM Rear Axle ERH-4.0L I6 Power Tech Engine GRZP-Left Remote Mirror GSZP-Right Remote Control Mirror GTZP-Manual Remote Mirrors HAA-Air Conditioning JHAP-Var Intermittent Windshield Wipers JJAP-Cigar Lighter KERP-DESCRIPTION NOT AVAILABLE MBJP-Black Front Bumper MDAP-Front License Plate Bracket MHAP-Black Windshield Moldings MMKP-Lower Grille Surround-Painted Silver PW7-Bright White Clear Coat RAAC-All Radio Equipped Vehicles RAFP-AM/FM Cassette Radio RCDP-4 Speakers SBAP-Power Steering SCGP- Wrapped Steering Wheel SFBP-Front Heavy Duty Shock Absorbers SGBP-Rear Heavy Duty Shock Absorbers SUA-Tilt Steering Column TBBP-Full Size Spare Tire TRPP- Tires TZAP-Goodyear Brand Tires WJDP-15X7.0 Styled Steel Wheels WLYC-All Steel Wheels YGEA-5 Additional Gallons of Gas Z01P-Rear Spring Group IZ 1B-GVW/Payload Rating Z58P-Left Front Spring Group Viii Z77P-Right Front Spring Group VII 2TCA-Customer Preferred Package 2TC 26C-Customer Preferred Package 26C 3VNA-Customer Preferred Discount 4HA-Special Scheduling Condition Link to comment Share on other sites More sharing options...
500 MJ Posted June 27, 2020 Author Share Posted June 27, 2020 FYI - there was no evidence of the rear axle or springs when I saw the truck. Wish I knew where that D44 went to... Link to comment Share on other sites More sharing options...
jdog Posted January 31, 2021 Share Posted January 31, 2021 Selling Dealer: LOU BACHRODT JEEP Rockford, IL Link to comment Share on other sites More sharing options...
