1J7FJ26S6ML607002
Sarkozi
build date:5/28/91
body: jl61
APAS-Monotone Paint
BAPS-75 Amp Alternator
BCCS-Dual 730 Amp Maint. Free Batteries
BGAS-Power Front Disc/Rear Drum Brakes
CUMS-Mini Floor Console
DHNS-Command-Trac Part Time 4WD System
DJHS-230MM Front Axle
DMMS-3.07 Rear Axle Ratio
DRJS-175MM Rear Axle
GACS-Tinted Glass Windows
GBBS-Tinted Windshield Glass
GCBS-Front Door Tinted Glass
GEHS-Fixed Door Vent Glass
GUAS-Open
HCDS-Do Not Use - See HCA
JCAS-85 MPH Primary Speedometer
KDNS-DESCRIPTION NOT AVAILABLE
KWSS-STRIPE/BADGE/MOLDING/COLOR
K3ZS-STRIPE/BADGE/MOLDING/COLOR
LAPS-Shift Indicator Warning Lamp
LBCS-Glove Box Lamp
LMAS-Halogen Headlamps
MB1S-Black Front Bumper
MFFS-Black Grille
MHBS-Bright Windshield Moldings
MMCS-Rear Door Solid Window Insert
MMGS-Belt Moldings
MMJS-Molded-In-Color Fender Flares
NAAS-Federal Emissions
NBKS-EVAP Control System
NF2S-18.5 Gallon Fuel Tank
QG5S-Hunter Green Metallic Clear Coat
RA8S-Delete Radio
SCES- Wrapped Steering Wheel
SFAS-Standard Duty Front Shock Absorbers
SGAS-Standard Duty Rear Shock Absorbers
TBCS-Compact Spare Tire
TBMS-Tire Carrier Winch
XBSS-Pickup Box
YAAS-Build To U.S. Mkt. Specifications
Z5AS-GVW/Payload Rating
1AAS-U.S. Dealer Retail
172S-Zone 72-Portland
*C1-DESCRIPTION NOT AVAILABLE
-SA-Charcoal
ALA- Decor Group
CBAP-Straight Back Bench Seat
CKA-Carpets - Floor and Cargo Area
DBBC-All Manual Transmissions
DDQ-5-Speed Manual Transmission
ERH-4.0L I6 Power Tech Engine
GRVP-Left Manual Mirror
JAY-DO NOT USE - See JP, KA classes
JGBP-Digital Clock
JHA-Var Intermittent Windshield Wipers
MBJ-Black Powder  Front Bumper
MDAP-Front License Plate Bracket
PG5-Hunter Green Metallic
SBAA-Power Steering-
SUA-Tilt Steering Column
TRNP-225/75R15 OWL Wrangler AT Tires
TZAP-Goodyear Brand Tires
WJN-15 Aluminum Wheels
WLZC-All Aluminum Wheels
YEP-Manuf Statement of Origin
YGEA-5 Additional Gallons of Gas
Z01P-Rear Spring Group I
Z64P-Left Front Group XIII
Z81P-Right Front Spring Group X
On 6/15/2020 at 8:18 PM, Sarkozi said:
1991 Jeep Comanche
4.0 AX15 30/35 Short bed
Build date: 5-91
Western Washington
Running driving but parked in the garage for about a year now.
standard grey interior with bench seat, no A/C
hunter green!!!!!  I need some photos!  :drool:
  • 3 months later...
  • 3 months later...
  • fiatslug87 changed the title to 1J7FJ26S6ML607002
