224ftlb Posted June 14, 2020 Share Posted June 14, 2020 89 mid-97 up swap to be reversed. White, blue interior, factory sliding rear window. Pretty well stripped. Link to comment Share on other sites More sharing options...
jdog Posted June 15, 2020 Share Posted June 15, 2020 you have a recall for the 02 sensor still needing to be done build date 11/22/88 body style jl61 APAS-Monotone Paint BGAS-Power Front Disc/Rear Drum Brakes BJAS-DESCRIPTION NOT AVAILABLE BKPS-10x2.5 Rear Drum Brakes CSRS-Passenger Assist Handles CUMS-Mini Floor Console DHNS-Command-Trac Part Time 4WD System DJHS-230MM Front Axle DMMS-3.07 Rear Axle Ratio GACS-Tinted Glass Windows GBBS-Tinted Windshield Glass GCBS-Front Door Tinted Glass GEHS-Fixed Door Vent Glass GNAS-Rear View Day/Night Mirror JAAS-Instrument Panel JBFS-Instrument Panel Black Bezel JCAS-85 MPH Primary Speedometer JKBS- KDAS-STRIPE/BADGE/MOLDING/COLOR K3ZS-STRIPE/BADGE/MOLDING/COLOR LAFS-Seat Belt Alert-Driver Seat only LAPS-Shift Indicator Warning Lamp LBCS-Glove Box Lamp LCJS-Overhead Lighting LMAS-Halogen Headlamps MB1S-Black Front Bumper MFFS-Black Grille MHBS-Bright Windshield Moldings MMCS-Rear Door Solid Window Insert MMGS-Belt Moldings MMJS-Molded-In-Color Fender Flares NBAS-Underground Calibration NBKS-EVAP Control System NDAS-Catalytic Converter NF2S-18.5 Gallon Fuel Tank QWBS-DESCRIPTION NOT AVAILABLE RACS-AM MTR Radio SCBS- Steering Whl SFAS-Standard Duty Front Shock Absorbers SGAS-Standard Duty Rear Shock Absorbers TBMS-Tire Carrier Winch WJKS-15X6.0 Styled Steel Wheels WMCS-Open XBSS-Pickup Box XFAS-(-35F) Protection Anti-Freeze YAAS-Build To U.S. Mkt. Specifications Z5AS-GVW/Payload Rating 1AAS-U.S. Dealer Retail 174S-Zone 74-Denver *B1-DESCRIPTION NOT AVAILABLE -Q8-DESCRIPTION NOT AVAILABLE BAYP-105 Amp Alternator BCYP-95 Amp Battery CBAP-Straight Back Bench Seat CKA-Carpets - Floor and Cargo Area DBBC-All Manual Transmissions DDX-5-Speed HD Manual Transmission DRKP-Dana 44/226MM Rear Axle DSA-Anti-Spin Differential Rear Axle EAAC-All Engines ERB- 4.0L I6 MPI Engine GFD-Rear Sliding Window GRZP-Left Remote Mirror GSZP-Right Remote Control Mirror GTZ-Manual Remote Mirrors HAA-Air Conditioning JAY-DO NOT USE - See JP, KA classes JGBP-Digital Clock JHA-Var Intermittent Windshield Wipers JJA-Cigar Lighter MDAP-Front License Plate Bracket NAF-High Altitude Emissions NHM-Speed Control PWB-DESCRIPTION NOT AVAILABLE RAAC-All Radio Equipped Vehicles RCAP- SBAA-Power Steering SUA-Tilt Steering Column TAAC-All Tires TBB-Full Size Spare Tire TNCA-P195/65R15 BSW AS Touring Tires YGBA-1 Additional Gallons of Gas YGGA-9 Additional Gallons of Gas Z01P-Rear Spring Group I Z66P-Left Front Group XV Z85P-Right Front Spring Group XIV 5ALA-DT-Vehicle Family Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 4, 2020 Share Posted July 4, 2020 Can you run this one again? The 8th digit being an "L" indicates a 4.0L the build sheet says EAFC- I4 Engine. Link to comment Share on other sites More sharing options...
Pete M Posted July 4, 2020 Share Posted July 4, 2020 3.07 gears. my money would be on the 4.0. Link to comment Share on other sites More sharing options...
jdog Posted July 4, 2020 Share Posted July 4, 2020 updated Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 4, 2020 Share Posted July 4, 2020 Link to comment Share on other sites More sharing options...
224ftlb Posted July 5, 2020 Author Share Posted July 5, 2020 She’s gone to the great partout in the sky. She will live on to save another. The guy I sold to is using her to resurrect this. Link to comment Share on other sites More sharing options...
jdog Posted April 1, 2021 Share Posted April 1, 2021 Selling Dealer: STEVE JOHNSON PONTIAC/GMC/JEEP IN Colorado Springs, CO Link to comment Share on other sites More sharing options...
