Can anyone tell me how to wire the Oil Pressure Gauge ?
I’m doing it from scratch, what type of sensor do I have to connect it to , and when wiring it where should you put the fuse ?
This is what the sensor should like, or a bigger gm style
Just remove the idiot light switch from the side of the oil filter housing then thread this in, one wire sender , there should be a wire already there.
I have no clue why you have to wire it all by hand, the wiring diagram I uploaded last week should break down what went to those connectors.
Personally I’d cut bait on the factory gauges if it’s this jacked up. Buy a gauge kit to find out what the motor is doing, keep the Speedometer.
I’m going to swap in a ax15 and np231 just to get accurate speed with bigger tires.
The 207 uses a reverse cut GM style speedometer gear which is impossible to find now. Plus there’s a ton more support for the 231 over the 207,
207 never failed me and has a monster chain the 231 only gets as HD a upgrade.
Anyway on this if you can’t make it work easily, do something different. Not worth the effort you have to put in to craft it by hand.
Sent from my iPhone using Tapatalk Pro
ok i looked up how the oil pressure sender that you showed in the pic works
it has 3 pins and the middle one is basically a variable resistor
my question now is how should i wire it to the gauge
what pin behind the gauge gets power and which one gets signal from the sender
Ok I took a look around and here what it’s got
these on top of the engine that look like there water temp related
The oil oil filter is just capped off with a plug
And  I found these two that look like they might work
this is on the oil pan on the right side of the engine (driver side)
This one is in the middle of the engine on the passenger side
Does anyone know know if I can use these to connect to the oil pressure gauge ?
i see that
but I'm trying to figure out what the other two sensors are for
and even if i go buy a new 2.8 oil pressure sender
how do i wire it to the gauge?
Ok so I found this
so it opperates between 0  -  80 psi
and from 1 ohm  -  88 ohms
so as the pressure goes up the resistance does too
and it looks like one pin on the back of the gauge gets positive
another gets negative and the third gets signal from the sender
now i need to figure out which pin it is that the sender goes to
The one in the pan is either a oil temp or level sensor, the one in the block is probably a knock sensor, id just go get a aftermarket gauge set, run a mechanical oil and temp gauge, a bit more accurate than the electric dash ones
ok than i will just go buy a new sensor
https://www.oreillyauto.com/detail/b/standard-ignition-5753/lighting---electrical-16777/sensors-16480/engine-sensors-25049/oil-pressure-sensor-switch-12875/9a4df8f34742/standard-ignition-1-terminal-oil-pressure-switch/ps15/5815754?q=PS15&pos=0
i will see if this operates between 0 - 88 ohms and if it does than i just gotta figure out how to connect it to the gauge
Ps155 is the correct style, one spade connector. The 2.8 harness should have a wire for it.
What’s going on with your dash? Is the harness messed up? Just the cluster?
you should just need to swap the sensor into the oil filter housing and connect it. The feed going to the instrument cluster shouldn’t need anything else.
Look at the wiring diagram from last week trace where the lines comes in to the plug and tap a feed from there. The fuse box already has a fuse for instruments. If working the rest of the cluster should work.
The best way to make to work reliably have the original engine and dash harness be in good order then drop a good 88-90 cluster in.
The sensor is a variable resistor, rated from 0 to 88 ohms. It should have a single contact. Power goes through the gauge, then grounds through the sensor. Oil doesn't touch the contact -- there's a diaphragm of some kind inside.
Yep eagles correct. Sorry. I didn’t click the link to see the switch, I read the link seemed like it was going to say PS155 which is like the original gm pressure sender.
Oh so I need one of the big fat gauges like this
Yes -- PS155. It says right under it that it's for use with gauge.
If your engine didn't even have a sensor for the oil pressure, how do you know the original wiring doesn't work? have you located the pigtail in the harness that's supposed to attach to the sensor? The quick and dirty test of the gauge doesn't even need the sensor. With the ignition on and the pigtail disconnected, the oil pressure gauge should read 80. Touch the pigtail to a good ground and the gauge should read zero.
I have removed all the stock wiring in my truck since it was to messy and dirty the best thing for me was to start over with new wiring, so far I have everything wired in the gauge cluster and working but the oil gauge is the only one I haven’t finished yet
What year is your cluster out of?
The cluster is the stock one that came with the truck (so whatever they had in 86)
ok I got the part now I’m gonna bench test it and see if I can figure out how it’s suppose to be wired to the gauge
The sensor isn't on the engine, so there's no pressure. How are you getting it to read 40 psi? Looking at your setup, shouldn't it be reading 0?
Looks like he's applying air to the sensor
