GM 173 V6 swap for AMC 258 I6
  • 3 months later...
  • Replies 54
considering swapping the 2.8 for a 4.0 instead of the 3.4 (too hard to find) despite the firewall. the 4.0 are a whole lot more common over here. my dad is willing to help me out with it so i am not concerned about all the work having to be done. but i am curious about the 4.5 stroker you can get from putting in the 258 crank. is that all you have to do or do you have to change the header or shorten the pistols or anything?
:cry: nobody is going to answer my question?
the delivery date wouldn't tell you anything about the engine bay and if the firewall was interchanged then would it? delivery date was 8-1-86. i am trying everything i can to figure out if it was a late or early 86. except for pulling the motor out. and that doesn't cost any money.
he is some info robert bryce has built 4.5 and has a lot of info
http://www.bc4x4.com/tech/bryce/stroker/stroker.cfm also dino site has alot of info as well http://www.jeep4.0performance.4mg.com/ hope this will quenches you thirst for info jamminz.gif I don't think they have a 3.4l 24v configuration just would like to know if the toyota 3.4l would work just a thought good luck
