Where to source 746 injectors?
I got my fuel pump installed, and now when the fuel pump runs, gas hemorrhages from the fuel rail. Since there is evidence my truck may have sat for 8 years, I'm not surprised the o-rings are done. My throttle body is filthy, I suspect the injectors are, too. Instead of replacing the o-rings, I want to replace the injectors. I've seen a lot of info that says the Bosch Part Number 0 280 155 746 for Volvo injectors are the ones to use. But where do I get a remanufactured set? I really don't want to fight with Cheap Chinesium quality control and have to send a leaking part back. KSuspension has a lifetime warranty, looks like a small business, and is kind of localish (next state east). A little expensive, at $139.
Suggestions?
I just bought a set of 6 refurbished Bosch 746s off eBay for 40 bucks free shipping. I was a bit sceptical at first but they ended up being real nice quality, no leaks, no stuck open valves. The seller is autopa7337 ( I have no affiliation with them just tryin to put my 2 cents in)
Sent from my moto e5 play using Tapatalk
If you get some off of eBay, which there are tons of sellers for these, make sure the set has been tested and matched for flow rate. This basically means the set has been tested to all have similar flow rates for fuel delivery. There are sellers that mine these from the JYs and just clean them up and put a new 5 cent o-ring on them and one of the injectors. If you don't go the eBay route, the guy Cruiser mentioned has been reconditioning these injectors for years and has a great reputation on several Jeep forums.
On 4/14/2020 at 5:42 AM, cruiser54 said:
Try contacting jhc7399@gmail.com
No email reply. I looked (e-stalked him) at Cherokee Forum:
Hey guys, sorry but for the time being I am going to have to shut this down. I am dealing with a nasty cancer diagnosis and just don't have the time or energy to do the injectors and make sure you get a quality injector/rebuild right now.
Hopefully down the road I can come back and get this rolling again, if not Thanks for all of the business. I tried to do a good job and make everyone who bought from me a happy customer.
Thanks Again.
Jeff
I saw he had been on, and made some posts, but it looks like he is a little under the weather right now.
