WahooSteeler Posted April 12, 2020 Share Posted April 12, 2020 Posted a couple times in the last couple days on hard to find parts, now I have another one. Other than "the junkyard", anybody have a source for these clips that hold the power window/door lock switch to the switch panel? The one on the left is proper as it has the extension that hooks on to the wiring harness block and the push tab in the center locks the switch in to the switch panel. The one on the right the hook is broken off so the harness could potentially work its way loose and fall off. Again, I've done some very extensive online searching with no luck. Link to comment Share on other sites More sharing options...
Warren Mohler Posted April 12, 2020 Share Posted April 12, 2020 I should have a bunch SOMEWHERE, will look n morning Link to comment Share on other sites More sharing options...
WahooSteeler Posted April 12, 2020 Author Share Posted April 12, 2020 1 hour ago, Warren Mohler said: I should have a bunch SOMEWHERE, will look n morning That would be fantastic. I was able to find part numbers, J4006536 and J4006546 but they are nowhere to be found so far. Thanks Warren! Link to comment Share on other sites More sharing options...
schardein Posted April 12, 2020 Share Posted April 12, 2020 I may have some also. Needed one a year or so ago, and grabbed several from the junkyard. Should be able to search a little today. Link to comment Share on other sites More sharing options...
WahooSteeler Posted April 12, 2020 Author Share Posted April 12, 2020 38 minutes ago, schardein said: I may have some also. Needed one a year or so ago, and grabbed several from the junkyard. Should be able to search a little today. Thanks!!! That's part of my problem, I don't have any "pick n pulls" nearby, only a couple of salvage yards that will only sell you the whole part or assembly so if it's a small part like these you're buying everything it's attached to. Link to comment Share on other sites More sharing options...
Drahcir495 Posted April 12, 2020 Share Posted April 12, 2020 How many do you need? I may still have a couple. Link to comment Share on other sites More sharing options...
WahooSteeler Posted April 13, 2020 Author Share Posted April 13, 2020 4 hours ago, Drahcir495 said: How many do you need? I may still have a couple. Minimum 2, 4 would be ideal.... Link to comment Share on other sites More sharing options...
Drahcir495 Posted April 13, 2020 Share Posted April 13, 2020 Gotcha - let me go look Link to comment Share on other sites More sharing options...
Drahcir495 Posted April 13, 2020 Share Posted April 13, 2020 Sorry Hoo only two. Pm me your address and I will get them in the mail for you Link to comment Share on other sites More sharing options...
