1990 Jeep Comanche Eliminator
4.0, AX-15, NP 231?, D30,D44?
8/89
North Central Kansas
Hopefully can pull parts off of it, but owner wants mint-condition money for it. But for now, it just sits.
No real out-of-the-ordinary features for a eliminator, fog lights, bucket seats, floor shift manual in a console, but it does have A/C and a sliding rear window, although it was rolled over and had a new top put on it, so that might not be standard. Colorado red I believe. 4x4.
Union road junkyard (not the real name, but I want to keep the owners name private)
is it rust free?  I know I'd probably want minty money if it was. :D  that'd be a prime candidate for a restoration!  :drool:
Nope, has some on the floorboards, and the top is starting to rust where it was patched. It’s mostly on the passenger side, not this side so much.
bad floors could be any MJ.  how are the undersides?  rockers?  not even sure why I'm asking at this point since there's no way I'm going to drive there and buy it.  :laugh:  forever the optimist!  :D  lol
Build Date 8/13/89
Body Model JL61
*Q7 Cloth Low-Back Bucket Seats
-SA Charcoal
152 Zone 52-Kansas City
1AA U.S. Dealer Retail
4HB Special Scheduling Condition II
5KP PLY GEM Industries
ALP  Safety Group
APA Monotone Paint
ARM Radio AM/FM Cassette
BA1 100 AMP ALTERNATOR
BCY 475 AMP BATTERY
BGA Power Front Disc/Rear Drum Brakes
CAC Low Back Bucket Seats
CDB Reclining Front Seats
CKA Carpets - Floor and Cargo Area
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMM 3.07 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAY DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JGB Digital Clock
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K2B STRIPE/BADGE/MOLDING/COLOR
K3R STRIPE/BADGE/MOLDING/COLOR
KLH
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
LNJ Front Fog Lamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MCA Rear Body Color Applique
MDA Front License Plate Bracket
MFK Body Color Grille
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PE4 COLORADO RED CC PRI PNT - HE4
QE4 COLORADO RED CC SEC PNT - HE4
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Steering
SCG Leather Wrapped Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TRN P225/75R15 OWL Wrangler AT Tires
WJH 15X7 Aluminum Wheels
WLZ All Aluminum Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z66 Left Front Group XV
Z85 Right Front Spring Group XIV
Frame seems good, bed is ok. Rockers have a hole in them, but you could probably get a good set of red flares that you’re looking for.
  • 2 months later...
On 4/8/2020 at 1:33 PM, JMO413 said:
Build Date 8/13/89
Body Model JL61
-SA Charcoal
ALP  Safety Group
APA Monotone Paint
BCY 475 AMP BATTERY
DRJ 175MM Rear Axle
EAA All Engines
JGB Digital Clock
JJA Cigar Lighter
KLH
LBC Glove Box Lamp
LNJ Front Fog Lamps
MMG Belt Moldings
RCD 4 Speakers
SBA Power Steering
TAA All Tires
XBS Pickup Box
Are you sure you got that Vin decoded right? I though all eliminators came with Dana 44s with Trac-lock optional.
That is what the parts catalog shows for that VIN. You can't really do it wrong.
Huh, guess I may be wrong then. Since it’s in tall grass I couldn’t really tell if the pumpkin was D35-ish or not. The itty-bitty spare blocked whatever view I had of it. I just thought that was standard on Metric Ton/Big Ton/Burley trucks and eliminators, and optional everywhere else. I’m guessing no Trac-lock either? Didn’t see that listed either.
  • 7 months later...
3 hours ago, Dickinson County Comanche said:
Interesting. I wonder if that dealer even exists anymore.
Quick Google search says no
