OptimusPreem Posted April 5, 2020 Share Posted April 5, 2020 1990 Jeep Comanche Eliminator 274,000 KMS / 170,000 Miles 4.0L Renix AX-15 Manual 5-Speed 4WD Box Length: Will Update Build date: Will Update Current Location: Saskatchewan, Canada Status: Owned By Me They're multiplying!!! Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 5, 2020 Share Posted April 5, 2020 Looks like you got a full length factory running boards. Nice. Someone will provide you with a build date and sheet. Link to comment Share on other sites More sharing options...
OptimusPreem Posted April 5, 2020 Author Share Posted April 5, 2020 14 minutes ago, eaglescout526 said: Looks like you got a full length factory running boards. Nice. Someone will provide you with a build date and sheet. Thanks for the heads up. I'll be more careful removing them. Link to comment Share on other sites More sharing options...
jdog Posted April 5, 2020 Share Posted April 5, 2020 That is NICE, it is also loaded 10/9/89 build date mjjl61- body code actual Canada truck APAS-Monotone Paint BGAS-Power Front Disc/Rear Drum Brakes CSRS-Passenger Assist Handles DHNS-Command-Trac Part Time 4WD System DJHS-230MM Front Axle DMMS-3.07 Rear Axle Ratio DRJS-175MM Rear Axle GACS-Tinted Glass Windows GBBS-Tinted Windshield Glass GCBS-Front Door Tinted Glass GEHS-Fixed Door Vent Glass GNAS-Rear View Day/Night Mirror GTZS-Manual Remote Mirrors JDBS-180 KPH Primary Speedometer K3WS-STRIPE/BADGE/MOLDING/COLOR LAPS-Shift Indicator Warning Lamp LBCS-Glove Box Lamp LCJS-Overhead Ambient Surround Lighting LMAS-Halogen Headlamps LMKS-Daytime Running Headlamps, High Beam MB1S-Black Front Bumper MDAS-Front License Plate Bracket MMCS-Rear Door Solid Window Insert MMGS-Belt Moldings NAAS-Federal Emissions NBKS-EVAP Control System NF2S-18.5 Gallon Fuel Tank NHKS-Engine Block Heater QW7S-Bright White Clear Coat SFAS-Standard Duty Front Shock Absorbers SGAS-Standard Duty Rear Shock Absorbers TBCS-Compact Spare Tire TBMS-Tire Carrier Winch XBSS-Pickup Box YACS-Build To Canada Mkt. Specifications Z5AS-GVW/Payload Rating 1ABS-Canada Dealer Retail124SZone 24-Canada-Prairie *Q7-Cloth Low-Back Bucket Seats- SA-Charcoal ACE-Jeep 60th Anniversary Edition ADAA-Light Group ADH-Heavy Duty Electrical Group ARM-Radio AM/FM Cassette BA1P-DESCRIPTION NOT AVAILABLE BCYP-95 Amp Battery CACP-Low Back Bucket Seats CDBP-Reclining Front Seats CKAP-Carpets - Floor and Cargo Area CUFA-Full Length Floor Console DBBC-All Manual Transmissions DDQ5-Speed Manual Transmission EAAC-All Engines ERB-4.0l I6 Engine GFDP-Rear Sliding Window GNBP-Driver Side Illuminated Sun Visor GNCP-Sun Visors w/Illum Vanity Mirrors GRZP-Left Remote Mirror GSZP-Right Remote Control Mirror HAA-Air Conditioning JAYP-DO NOT USE - See JP, KA classes JGBP-Digital Clock JHAA-Var Intermittent Windshield Wipers JJAP-Cigar Lighter KLHP-DESCRIPTION NOT AVAILABLE K2BP-STRIPE/BADGE/MOLDING/COLOR LAJP-Headlamps On Warning Chimes LBBP-Courtesy Lamps LBDP-Ash Tray Lamp LBEP-IP LED Ambient Light Pipe LDHP-U/Hood, Removable Lamp LHDP-Headlamp Off Time Delay LNJP-Front Fog Lamps MBJP-Black Powder Coated Front Bumper MCAP-Rear Body Color Applique MFKP-Body Color Grille MHAP-Black Windshield Moldings MMKP-Lower Grille Surround-Painted Silver NHM-Speed Control PW7-Bright White Clear Coat RAAC-All Radio Equipped Vehicles RAFA-AM/FM Cassette Radio RCDP-4 Speakers SBAP-Power Steering SCGP-Leather Wrapped Steering Wheel SUAA-Tilt Steering Column TAAC-All TiresTRN P225/75R15 OWL Wrangler AT Tires WJHP-15X7 Aluminum Wheels WLZC-All Aluminum Wheels YGAA-Without Billable Fuel Z01P-Rear Spring Group I Z66P-Left Front Group XV Z85P-Right Front Spring Group XIV 3N8A-Drive Away Program Tracking 4CPA-Federal A/C Excise Tax Link to comment Share on other sites More sharing options...
jdog Posted April 5, 2020 Share Posted April 5, 2020 28 minutes ago, eaglescout526 said: Looks like you got a full length factory running boards. Nice. Someone will provide you with a build date and sheet. ever see this code? ACE-Jeep 60th Anniversary Edition Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 5, 2020 Share Posted April 5, 2020 2 minutes ago, jdog said: ever see this code? ACE-Jeep 60th Anniversary Edition No. That code would've been used in 2003. Kind sucks that our MJ's never saw an anniversary milestone while in production. Almost with 93 for the 50th. Link to comment Share on other sites More sharing options...
OptimusPreem Posted April 5, 2020 Author Share Posted April 5, 2020 Thank you so much for the VIN decoding; Absolutely love this sort of thing. Link to comment Share on other sites More sharing options...
Pete M Posted April 5, 2020 Share Posted April 5, 2020 33 minutes ago, eaglescout526 said: No. That code would've been used in 2003. Kind sucks that our MJ's never saw an anniversary milestone while in production. Almost with 93 for the 50th. yeah, the "Olympic Edition" is just not the same thing. Link to comment Share on other sites More sharing options...
jdog Posted February 10, 2021 Share Posted February 10, 2021 Selling Dealer: Z B JEEP EAGLE LTD Moose Jaw, SK (CAN) Link to comment Share on other sites More sharing options...
