Hello. I ran my carfax on the VIN. Says its a 1988 as I assumed. But I think my engine was swapped out somewhere around 2006 as the mileage has moved around over the years. I am trying to determine if this is the original engine for this truck? As well as making sure i order right parts as I put it back together.
Here is what I know.
The Head reads 2686 with a large 89 on the top in the middle
The block reads 53005535 on driver side front.
The block reads 6-10-89 on driver side near firewall.
So all signs are leading to an 89 engine in a 88 Comanche?
The tag on the passenger side near distributor is almost unreadable, as best i can make out is only 6MX2I
Any help would be greatly appreciated. Thank you.
When ordering parts, 87-90 are identical as far as the motor goes, there little to no difference on all the other parts, and those that differ are factory upgraded/superceded parts (thebdistributor is one, the 89-90 having less leaking issues than the 87-88).
2686 is the coreect head casting used from 87-90
53005535 is the correct Block casting used from 87-90
It is possible the motor was replaced with a newer motor in better condition. But other than a newer build date than the original, it is identical in every way to the 88 motor.
