Alright so hopefully this makes sense ill add pictures to help. Basically i have no DRL and my side light are not working. No lights are on for my DRL. The side markers and not on nor the white bottom ones. Next when i put my turn signal only the bottom white one works. The side markers are not blinking for turn signals or being on for the DRL. I checked with my light tester and i have power going to the bulbs , both blinking and the constant wire have power. Switched the bulbs, and that didn't fix it. All in all,  no DRL and side markers are not working for any task, but i have power going to them.
not my car in the pic btw
Well..this is a stab but by your name you have an 87 MJ. I believe if not all Renix MJ's did not have DRL or the side markers blink. When you pull out the switch to turn your lights on, the side markers will stay on and when you turn on your signal they will not blink. That feature appeared on newer XJ's.
But all this will depend on weather you have the original Renix harness and set up or the newer HO swap.
If you want DRLs there’s a switch lower left of the steering wheel. Pull it out. Now you have DRL.
Be sure to push it back in when you get out of the truck or else your battery will die.
The MJ, from the factory in the US, did not come with DRL.  Only regular manually controlled headlights.
Do you have an aftermarket DRL setup?
