Stroker vs Stock
MJ Engine
9 members have voted
  1. 1. 4.6 Stroker or 4.0
    • Buy new stroker kit cheap from friend
    • Buy new crank
32 minutes ago, 89 MJ said:
Ok. I got more info. I was told that the cylinder walls would need to be honed and that it is a poor mans stroker kit. I could be a 4.2 and a 4.0 for $75. I would put the 4.2 crank and rods in the 4.0 block.
What does everyone think?
Cylinder walls "honed"? Not bored? Does this kit include pistons, or is it just a crank shaft?
If you just put a 4.2L crank and rods into a 4.0L block, because of the difference in deck height you will have very high compression. To correct for that, IIRC, you will need special pistons.
I think you would be better served to rebuild your engine as a 4.0L and, if you want a bit more power, just go for a bigger cam.
That information is just not helpful. You don’t know what, pistons, con rods, crank or bearings come with it if any. You have no way of calculating compression, fuel needs, quench or any other useful metric. I agree with the other suggestions here. Just rebuild it as a 4.0
10 hours ago, JustEmptyEveryPocket said:
Lets change the question around: What are you hoping to get out of this? As in what is your rational for putting time and money into building a stroker?
The engine has just gotten worn out and has a knock. It also has a hard time doing 70 mph.
Alright. That is probably the route I’ll go.
