New Used AW4 ?
Well I lost 2 & 4th gear in the XJ :helpme:. I know this because obviously I can tell and AAMCO confirmed it. They quoted me 2100 to 2500. Yikes. It is 1990 4.0 AW4 4x4. I am buying another 4wd AW4 with 89k on it. It is a 93-95. My question is can I put it in and just attach everything from the 90? I already have the newer np242 ready to go in with matching spline count, so I am good there.
Fork that! Just pick up used AW4 beat the crap out of it for another 200k and repeat again. Here's a good link going over what AW4 works
https://www.naxja.org/forum/showthread.php?t=1053970
Ya, I just swapped in a used aw4 in mine after I lost reverse. $150. It's easy to swap and you could do it 10 times for the cost of rebuilt to stock one.
Just a heads up, I ran into this issue, if you have a 98 (and whatever other years apply) use the tranny mount that came with it in whatever year jeep you have. I fought my 01 tranny mount then realized I needed the 98 mount that I took off the swap tranny...
Sent from my SM-G973U using Tapatalk
