92' jeep comanche
Model: CMH
4.0, ax15, 231, d30, ford 8.8
Currently in sw kansas
Runs great, bought in the middle of being built by previous owner, looks as though most things have been improved upon... 1ton leafs, upper and lower control arms with the ball and socket ends, billstein shocks, moog ends, Spicer u joints, 32" kenda lever mts, just needs drivin more to test for leaky seals and gaskets... not sure how much he drove it...  have lots or spare parts, OEM running boards, roll bar, skid plates, seat belts, turbine center caps, 2 radiators, brand new carpet, tan leather bucket seats that fold forward with mounts(I put the bench in it and plan to leave it) d30 axle shafts.
It is dark blue with red and gray grafic but has 97' doors... I will try to get a pic soon... I plan on keeping it forever and building it as it wears! Solid as can be right now...
*C1 TRIM STYLE C1 - CLOTH &&&& VINYL BENCH SEAT
-SA Charcoal
163 Zone 63-Dallas
1AA U.S. Dealer Retail
25C Customer Preferred Package 25C
2TC Customer Preferred Package 2TC
3VN Customer Preferred Discount
4EA Sold Vehicle
4HA Special Scheduling Condition I
4M1 Retail to Bid Diversion Tracking
4UA SCA Tissue North America LLC
ADL Skid Plate Group
ALA SE Decor Group
APA Monotone Paint
BAR 90 Amp Alternator
BCD 500 Amp Maintenance Free Battery
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMM 3.07 Rear Axle Ratio
DRJ 175MM Rear Axle
ERH 4.0L I6 Power Tech Engine
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAY DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K3Z STRIPE/BADGE/MOLDING/COLOR
KER
KWR STRIPE/BADGE/MOLDING/COLOR
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBK EVAP Control System
NF5 Fuel Tank - 23 Gallon
PB8 MIDNIGHT BLUE MET CC PRI PNT - HB8
QB8 MIDNIGHT BLUE MET CC SEC PNT - HB8
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCG Leather Wrapped Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TBC Compact Spare Tire
TBM Tire Carrier Winch
TMW P265/60r18 BSW A/S All Terrain Tires
TZA Goodyear Brand Tires
WJN 15" Aluminum Wheels
WLZ All Aluminum Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z66 Left Front Group XV
Z85
Right Front Spring Group XIV
Build date 4/15/92
Body code JL62
ooooooo!  that's a pretty late build date!  and well apportioned at that!  :brows:    try not to cut anything so you can return it to stock when you find out it's quadrupled in value later on.  :L:  you own one of the last MJs ever built.  :beerchug:
do ignore the "Power Rack and Pinion Steering", that's a reused code.
  • 11 months later...
