Eagle Posted October 2, 2007 Posted October 2, 2007 if not, instead of the 89 style grille I have, I could send you the 94 style (3 piece) that has the upper and lower trim pieces built in...for $5 more... Won't work. The entire header has to be changed to use the newer style grille.
JeepcoMJ Posted October 3, 2007 Posted October 3, 2007 if not, instead of the 89 style grille I have, I could send you the 94 style (3 piece) that has the upper and lower trim pieces built in...for $5 more... Won't work. The entire header has to be changed to use the newer style grille. I will install it on one of my grilles on friday. it is identical except for the addition of the trim edging that's on our older rigs. the only difference is that you have to cut some of the older header panel out behind the corner markers in order to make it work. if I find that that won't make it work either, then John, I have the rest of the trim pieces that you would need regardless to make it a complete truck. but they're kinda surface rusty (or theyr'e at least faded grey..can't remember)
JohnQ Posted October 3, 2007 Author Posted October 3, 2007 if not, instead of the 89 style grille I have, I could send you the 94 style (3 piece) that has the upper and lower trim pieces built in...for $5 more... Won't work. The entire header has to be changed to use the newer style grille. I will install it on one of my grilles on friday. it is identical except for the addition of the trim edging that's on our older rigs. the only difference is that you have to cut some of the older header panel out behind the corner markers in order to make it work. if I find that that won't make it work either, then John, I have the rest of the trim pieces that you would need regardless to make it a complete truck. but they're kinda surface rusty (or theyr'e at least faded grey..can't remember) I think the header I have is a late model. I will have to pull it off and see if I can find the manfacturing date. I know the wire harness has two plugs in the middle by the grille.
JeepcoMJ Posted October 3, 2007 Posted October 3, 2007 John, is it kinda "hollow" behind where the upper screw for the corner markers would go? could ya take some closer pics, I can tell ya what it is...
JeepcoMJ Posted October 3, 2007 Posted October 3, 2007 nvm. I can tell it's the later style anyways. so mine will work with no mods :D
JohnQ Posted October 3, 2007 Author Posted October 3, 2007 What do I need to put the dana 44 out of the 89 2wd, onto my 88 4x4? Will I have any issues with my driveshaft?
offroader461 Posted October 3, 2007 Posted October 3, 2007 should just bolt in...your driveshaft would be fine...i would just make sure it the correct ratio to match your front axle otherwise you will run into major problems....lets get a pic of the D44 in the back of you 2wd one
JohnQ Posted October 3, 2007 Author Posted October 3, 2007 .............lets get a pic of the D44 in the back of you 2wd one Dana 44!
offroader461 Posted October 3, 2007 Posted October 3, 2007 great find...just make sure its the same ratio as the front or youll have to regear front or rear to match
feerocknok Posted October 3, 2007 Posted October 3, 2007 That tag on the left side of the cover should definitely say the ratio under the grease spot.
JohnQ Posted October 5, 2007 Author Posted October 5, 2007 nvm. I can tell it's the later style anyways. so mine will work with no mods :D Here is a better pic of the header. Let me know when you get a chance to check on the shipping.
jtdesigns Posted October 5, 2007 Posted October 5, 2007 What do I need to put the dana 44 out of the 89 2wd, onto my 88 4x4? Will I have any issues with my driveshaft? Hey JohnQ think you can get a good picture of the drive shaft and axle flange?
JohnQ Posted October 5, 2007 Author Posted October 5, 2007 What do I need to put the dana 44 out of the 89 2wd, onto my 88 4x4? Will I have any issues with my driveshaft? Hey JohnQ think you can get a good picture of the drive shaft and axle flange? I can get you one tomorrow. I'm at work until 2 am.
jtdesigns Posted October 5, 2007 Posted October 5, 2007 What do I need to put the dana 44 out of the 89 2wd, onto my 88 4x4? Will I have any issues with my driveshaft? Hey JohnQ think you can get a good picture of the drive shaft and axle flange? I can get you one tomorrow. I'm at work until 2 am. Cool Thanks.. Good luck with that 2am shift :eek:
