schardein Posted January 19, 2020 Share Posted January 19, 2020 I did my monthly junkyard run today and made a great discovery. While looking at the engine compartment of a Cadillac CTS, I found the same connector that is used on the taillight harness on my 91 MJ. I think it will be correct for 87-91 MJ. This will provide a cheap source for a replacement connector, or to make a plug-and-play trailer wiring harness that doesn't require cutting and splicing the factory harness. The Cadillac application has some wires in different locations than the MJ, so it will require unpinning some wires and moving them to the proper place. This one came from a 2003 CTS, but I suspect many early to mid 2000s models like the CTS, DTS, and STS may use the connector also (disclaimer: I am not a Cadillac expert). Included is a picture of where the connector is located. It required a 10mm (socket size) bolt to be removed from a retaining bracket before clipping it out of the harness. Additional previous discussion on this topic is located here: Link to comment Share on other sites More sharing options...
500 MJ Posted February 7, 2020 Share Posted February 7, 2020 I just pulled this connector from a 2007, 2004 CTS and 2005 SRX. These were on the cars with the 3.6L V6. Northstar V8 cars did not have them, at least not in that location on the engine. Link to comment Share on other sites More sharing options...
schardein Posted February 8, 2020 Author Share Posted February 8, 2020 5 hours ago, 500 MJ said: I just pulled this connector from a 2007, 2004 CTS and 2005 SRX. These were on the cars with the 3.6L V6. Northstar V8 cars did not have them, at least not in that location on the engine. Link to comment Share on other sites More sharing options...
Pete M Posted February 8, 2020 Share Posted February 8, 2020 crazy! Link to comment Share on other sites More sharing options...
500 MJ Posted February 8, 2020 Share Posted February 8, 2020 For whatever reason, that yard I went to had a bunch of those Cadillacs in it and about 50/50 were the V6/V8. I’m going to toss a few of the connectors up in classifieds, there are plenty more there if folks need me to pull them. Link to comment Share on other sites More sharing options...
schardein Posted March 20, 2023 Author Share Posted March 20, 2023 Since this thread was recently referenced in another post, I wanted to add some updates. This is my current knowledge on the MJ tail light harness connectors. 1986 MJs use a flat 6 weatherpack connector. I believe this connector is also used in 1984-86 XJs. 1987-1990 (maybe some 91s?) MJs used a mixed Metripack connector with five 150 series pins and two 480 series pins. Identical connectors can be sourced from some Cadillacs mentioned at the beginning of this post. 1991-1992 use a different 6 pin connector. These connectors can also be found in 1993-1994 Jeep Grand Cherokees (ZJ). They are used for the same thing, the tail light sub harness connection, and are located in a similar place, on the driver rear, clipped to the frame. Link to comment Share on other sites More sharing options...
Halton Smith Posted October 5, 2025 Share Posted October 5, 2025 Anyone able to tell me which wire does what on the 86 plug or information on a 95 Cherokee plug. Gotta do some sort of splicing for my swap. Thank ya much! Link to comment Share on other sites More sharing options...
Pete M Posted October 6, 2025 Share Posted October 6, 2025 offhand I don't know for sure. 86 has a lot of weirdness. but it should be fairly easy to test each with a multimeter or test light. it'll have the same 5 wires as the plug above. Link to comment Share on other sites More sharing options...
