tarmac2dirt Posted December 27, 2019 Share Posted December 27, 2019 as i keep doing more to my 88 comanche i been look for the original build sheet. Either its gone or i have not come across it yet. Did the MJ's have a build sheet and where should i find it? Link to comment Share on other sites More sharing options...
fiatslug87 Posted December 27, 2019 Share Posted December 27, 2019 Some say in the door, some under the bench seat. If you post your VIN in the Registry eaglescout526 will post the build sheet (not 100% accurate). Link to comment Share on other sites More sharing options...
tarmac2dirt Posted December 27, 2019 Author Share Posted December 27, 2019 Thanks for the answer fiatslug87, I found nothing in the doors. I will check under the seat when i get it back from the paint shop. Having it repainted the orig. color (deep baltic blue). Will jump into the interior when i get it back , new seat upholstery, new carpet. Need to pull the dash and replace the heater core too. Thanks again, Paul Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 27, 2019 Share Posted December 27, 2019 I found a piece of the build sheet under the floor vents when I tore my dash out. And fiat is right. I will post up a build sheet of your truck in the registry. Link to comment Share on other sites More sharing options...
schardein Posted December 28, 2019 Share Posted December 28, 2019 I found the original build sheet in my 91, stuffed in the springs on the bottom of the pass side of the bench seat. Link to comment Share on other sites More sharing options...
