Eric A Posted December 12, 2019 Share Posted December 12, 2019 My 89 MJ: 4.0, 4 spd Automatic on the column, 4x4, long bed,... lo_ line instrument gauge cluster; only large fuel gauge and speedo, lights for the rest ...The fuel gauge didn't work .... In the process of swapping in another one, the needle popped off! It won't go back in/ on. So I'm stuck ... No working fuel gauge! Aside from swapping in another gauge or upgrading to a different gauge cluster, are there good aftermarket (autometer?) Gauges that will work with a Jeep fuel pump/ level sending unit? I'm thinking of fabbing an entire gauge cluster with Autometer or similar reliable gauges. I understand I'll need to change oil & water sending units, what about ammeter and fuel? Thanks for any help, experiences you can share. Link to comment Share on other sites More sharing options...
Jeep Driver Posted December 12, 2019 Share Posted December 12, 2019 I cannot speak to Autometer, however, Speedhut is fully programmable. Doesn't matter what sender or how accurate it is. Link to comment Share on other sites More sharing options...
fiatslug87 Posted December 12, 2019 Share Posted December 12, 2019 I have one you can have from a '90 (worked when pulled over 10 years ago) for the price of shipping, pm me if interested. Link to comment Share on other sites More sharing options...
Minuit Posted December 12, 2019 Share Posted December 12, 2019 What makes you think it's the gauge itself and not the level sensor itself or the wiring between the level sensor and gauge? Those are much more likely culprits. Link to comment Share on other sites More sharing options...
kazam Posted December 12, 2019 Share Posted December 12, 2019 Greetings, It read like 'Eric A' had the actual needle on that Jeep gauge physically fall off; may be I did read that otherwise. I changed over from the 'Big Fuel Gauge' cluster to an earlier 'XJ 'cluster with a mechanical tachometer drive et cetera. I have not adjusted the tachometer from and inline-six to an inline-four yet because I have a lot of time with engines and, I am thankful; I have a marker pen too. I really would like to get to calibrating the tachometer with my Comanche. Thanks for help keeping me focused. Link to comment Share on other sites More sharing options...
