KANTANKRUS Posted November 20, 2019 Posted November 20, 2019 I need to replace bulb sockets. Also, as i understand that some company sells brass contacts for our fuse boxes, where can I purchase them at? Please advise.
eaglescout526 Posted November 20, 2019 Posted November 20, 2019 Turn signal new metal style- 3764863. For the side markers, they are not serviceable. You’ll have to find an aftermarket to fit. I know crown makes the turn signal socket. Try this number 56018638. But it seems like both numbers don’t show up at all to cross reference to crown. Not even the old 83501000 number doesn’t show up.
Wounded_Fighter Posted November 21, 2019 Posted November 21, 2019 I used a few of these to rewire my fuse block. https://www.amazon.com/gp/aw/d/B000CO7I04?psc=1&ref=ppx_pop_mob_b_asin_title
KANTANKRUS Posted November 21, 2019 Author Posted November 21, 2019 1 hour ago, Wounded_Fighter said: I used a few of these to rewire my fuse block. https://www.amazon.com/gp/aw/d/B000CO7I04?psc=1&ref=ppx_pop_mob_b_asin_title Is it difficult to do? Could I simply use these, in my OEM fuse block? https://www.amazon.com/terminal-vehicle-instrument-spring-BX2201-2/dp/B077QK2KKR/ref=asc_df_B077QK2KKR/?tag=hyprod-20&linkCode=df0&hvadid=330426419246&hvpos=1o8&hvnetw=g&hvrand=5738244723008417193&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9051543&hvtargid=pla-678047445747&psc=1
schardein Posted November 21, 2019 Posted November 21, 2019 For those yellow rubber sockets used on the front markers: Those are the same thing used for the under dash courtesy lights in our XJs & MJs. Since the under dash lights aren't subjected to years of exposure to the elements like the marker lights, they generally look like new. I don't believe the marker light sockets have a disconnect at the harness, so they would have to be cut off. Then the connector from a courtesy light could be cut off, and the replacement socket spliced on either using a soldered connection or a crimp terminal, then covered with heat shrink. I've got extra courtesy light sockets if you are looking for some.
Wounded_Fighter Posted November 21, 2019 Posted November 21, 2019 12 hours ago, RestoringNV said: Is it difficult to do? Could I simply use these, in my OEM fuse block? https://www.amazon.com/terminal-vehicle-instrument-spring-BX2201-2/dp/B077QK2KKR/ref=asc_df_B077QK2KKR/?tag=hyprod-20&linkCode=df0&hvadid=330426419246&hvpos=1o8&hvnetw=g&hvrand=5738244723008417193&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9051543&hvtargid=pla-678047445747&psc=1 You could but some of the pins are common grouped. 4 in series, 3 in series.. etc. I wouldn't call it hard to do. Just time consuming to do. Gotta make sure it all goes back correctly
KANTANKRUS Posted November 21, 2019 Author Posted November 21, 2019 4 hours ago, schardein said: For those yellow rubber sockets used on the front markers: Those are the same thing used for the under dash courtesy lights in our XJs & MJs. Since the under dash lights aren't subjected to years of exposure to the elements like the marker lights, they generally look like new. I don't believe the marker light sockets have a disconnect at the harness, so they would have to be cut off. Then the connector from a courtesy light could be cut off, and the replacement socket spliced on either using a soldered connection or a crimp terminal, then covered with heat shrink. I've got extra courtesy light sockets if you are looking for some. I am, but let me do a little digging to see, just how many parts of the 97+ XJ header bulb sockets, differ from the 87 Comanche sockets. If by doing this swap makes my life easier, then this swap will get done sooner, rather that later.
