Chevy Adapter
89 MJ
I have decided I might LS swap my MJ because it knocks, misses, has an erratic idle, and leaks oil.
That said, I need one of these: https://www.morris4x4center.com/chevy-v8-v6-to-jeep-ax15-bellhousing-adapter-kit-manual-transmission-168t-flywheel-and-gen-3-engines-aa-712567v.html
If you have one for sale, please lmk.
Thanks
28 minutes ago, Jeep Driver said:
Follow his build.
No one will have one of those adapters just laying around and you won't get one cheap and you don't want that anyway.
Thanks!
When I did a 5.3 swap in my CJ, I used the Novak adapter plate to adapt a Chevy truck bell housing to a NV3550.  The later Chevy truck bell housing has a built in mount for an external hydraulic clutch release cylinder.  They make a similar adapter for the AX15:
https://www.novak-adapt.com/catalog/adapters/engine-to-transmission/ax15/kit-gmax15/
When initially preparing for my swap, I found a guy local to me that had an AA adapter bell housing, flywheel, and clutch parts laying around and I got it for cheap.  After some mockup, I didn't like it and ended up selling it to buy the Novak stuff.
Noted, thanks!
