1990 - No Power Supplied to Circuit Breaker at Interior Fuse Box
Hi you glorious group of people. I'm new here and am really digging my "new" truck, and am getting into the part of the project I'm not so great at; wiring. The PO has really done some unique wiring "fixes" that I really need to correct. Tin Foil Jumped Fuses, Jumped Wires, Splicing Into The Steering Column, YUCK. So I've corrected the obvious wiring and am now in need of a wiring diagram or advice. I have no power to the blower motor, and no signal lights and there may be more issues but I'm unaware at the moment as I've just been focusing on those aspects. I've determined there is no power to the circuit breaker at the fuse box. When I ran a direct lead from the battery to the circuit breaker both the blower motor and signal lights begin to function. Any tips on where I should look or where the wiring is routed to try and find the problem?
Thanks!
If your MJ has a manual transmission, the clutch master cylinder may have leaked hydraulic fluid onto the fuse panel. That corrodes and destroys the contacts. You may need to source a replacement fuse panel from a wreck with an automatic.
